LNF boost gauge does not work in LSJ car
is there a part number so i can get it. Also will that sensor work in the SS/SC. Thats what i been trying to find out for the past week. Pissing me off i paid $100 to get a 30psi gauge and its saying im hitting 27psi with my TVS
man thats some serious boost!!!!!! ill see if i can find it for you
lol, i wish i was hitting that. When i had my M62 on last with with the 2.8" pulley. I had the canadian ss/sc gauge, was hitting 130kpa (18psi) then switched to the american ss/tc gauge and it said 25psi. Then put my TVS without a tune and it says 27psi...need that to be correct, should be around 20-21psi with the TVS once tuned
GM 12223861 3
http://www.detroitturbo.com/cart/pro...products_id=66
pretty sure this is it have one of the service guys verify it like pull the diagram on the ss/tc and match the sensor.
the map and pigtail (gm 12223861 - 3 Bar MAP sensor, 15305891 - pigtail harness)
i think you need hptuners to make it work though i think
Last edited by purplehaze03; 07-13-2009 at 09:01 PM. Reason: Automerged Doublepost
You overpaid for that gauge. CED has it for about $57 + shipping. http://www.crateenginedepot.com/stor...5-P2291C0.aspx
GM 12223861 3
thanks. I'm getting tuned on friday with HPT so ill find out how it works.
well it will be a few weeks until i can get those parts but yea ill keep everyone posted, or just check out my build thread. https://www.cobaltss.net/forums/canadian-mid-west-112/snakes-tvs-build-179214/
I'll give the dealership a call tomorrow and see how much they r going to charge me
the reason its not plug and play is the ss/sc uses a 2.5 bar map sensor, the ss/tc uses a 3 bar map sensor. both use a 0-5 volt signal, but they use a different scale. as already stated, you need to install a 3 bar map and have the pcm tuned for it.
or just get an aftermarket mechanical boost gauge
