A look at the Intercooler pump.( Lots of pics)
Old 02-23-2010, 02:16 PM
06yellowburdSS's Avatar
What signs are we looking for as to determine whether or not our IC pump is failing, or has failed?
Old 02-23-2010, 02:54 PM
phatnackySS's Avatar
Originally Posted by harryresh
while i was pulling the end of the motor apart, a bent up washer looking piece fell out of the motor. where does this go?
post a pic if you can.
Originally Posted by shadowfaxss
Mine looked this bad as well when I took it apart. Replacing the brushes would most likely not last that long. The comutator/armature that the brushes contact are severely worn as well (as illustrated in the fifth picture).
This is true , the first time i pulled the motor apart the commutator was fine , the brushes were just worn and dust was keeping them from sliding and making contact. so i cleaned it and put it back together , once i found brushes (some 5k+ miles later ) one of the bruises had turned sideways and scored the commutator. so for some this fix will work, for others if it looks like mine did , don't expect it to last long, so far mine is still going strong.
look at the intercooler filler neck, if its bubbling churning while the car is running then its working.
Old 02-23-2010, 03:34 PM
Illini_06SS's Avatar
Meh. I'll just spend $100 and get a new motor...
That seems like a lot of work and with a 90% chance of massive frustration.
Old 02-24-2010, 01:59 PM
harryresh's Avatar
[QUOTE=phatnackySS;4713180]post a pic if you can.
Here is a pic of the "washer" that fell out of my intercooler pump motor while taking it apart...
Old 02-24-2010, 03:05 PM
[QUOTE=harryresh;4716360]
That is odd i dont rember seeing anything like that
Old 02-24-2010, 05:00 PM
troyss's Avatar
How can I tell if its dead or not? the IC pump
Old 07-13-2010, 06:56 PM
SprChrg4Life's Avatar
When I tried to bleed my intercooler system for 3 hours after a OTTP exchanger install, it finally dawned on me that my pump must not be working... bench tested it, nothing! Damn you pump!!
This how-to helped me save $$ which is always a good thing. Excellent, clear cut info and great pictures. My dad and I had a blast reconditioning it... being a retired electrician, he was totally into rebuilding the motor. Anything involving electricity is of course right up his alley heh. Infact he wanted to rewind the armerature so it'd be more powerful
Thanks a million!
Old 07-19-2010, 12:16 PM
NinjaHampster's Avatar
sub'd
whats the part number? i tried using the ones from the pic's but no luck and the bosch website was no help. also is this a dealer item only or can you get one at autozone?
Last edited by NinjaHampster; 07-19-2010 at 12:16 PM. Reason: Automerged Doublepost
Old 07-19-2010, 03:54 PM
Originally Posted by NinjaHampster
sub'd
I'll have to look around for it . every ace has different parts , i went to 3 in my area before i found ones that fit.
Old 07-19-2010, 04:01 PM
appreciate it
Old 07-19-2010, 06:02 PM
  #36
HunterKiller89's Avatar
sub'd
autozone can order one for you...
ask them for the intercooler pump from a cobaltss, ford lightning, 03-04 mustang cobra, etc.
They can order oem parts, and its an oem pump on several cars
05-28-2022 03:47 AM
06MetallicBalt
08-17-2021 03:40 PM
dennis69
10-20-2015 04:49 PM
10-13-2015 09:32 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: A look at the Intercooler pump.( Lots of pics)
