LSJ Important Warning!
Old 08-07-2009 | 01:46 PM
  #276
06G85's Avatar
I've gotten the LOW COOLANT display, but the coolant is fine. Would this be an outcome of the same failure???
Temp was up to 207 and I turned the heat on, (I'm doing about 45 mph during this time), shifted to neutral and revved up to 4K a couple times, temp went down to 187 in about 10 seconds.
Would I be able to just go to the dealer and have them look at the intercooler to make sure I don't have this issue if I'm concerned that i do?
Old 08-07-2009 | 02:11 PM
  #277
Pyros777's Avatar
There are three main temperatures to keep track of on this car.
IAT1: Intake Air Temperature BEFORE the supercharger
IAT2: Intake Air Temperature AFTER the supercharger
ECT: Engine Coolant Temperature.
IAT1 is for the most part very close to ambient.
IAT2 is the temperature of the air after flowing through the laminova cores of the superchargers coolant circuit.
The ONLY way to view your IAT1 or IAT2 temperatures is by using an OBDII scan tool like HPTuners or an Aeroforce Interceptor.
ECT is its own separate cooalnt circuit and has NOTHING to do with the superchargers coolant.
The driver information center will never report low coolant for the supercharger's coolant circuit because there is no coolant level sensor for it.
The "LOW COOLANT" message you are seeing is in reference to your engine's coolant reservoir, located to the right of your fuse box. You may need to add some coolant.
Old 08-07-2009 | 02:20 PM
  #278
06G85's Avatar
Collants fine. It's happened twice. But the first time I was under accelleration and the second i was on an upward incline. So the coolant probably exposed the sensor a little.
Old 04-12-2010 | 11:15 AM
  #279
chris88z24's Avatar
Bump.
Old 04-12-2010 | 03:10 PM
  #280
Nfangelo's Avatar
hey so after i read this i figured id go check mine for ***** and giggles. well i toke the cover off and it was slightly below the word "fluid" so i turned the car on. and didnt here the dull whine i thought i should so i tapped it with a hmmer and still nothing. i didnt see much movement in the fluid. any advice?
Old 04-12-2010 | 03:14 PM
  #281
ralliartist's Avatar
Originally Posted by Nfangelo
any advice?
yea, go ahead and start panicking right about now.
Old 04-12-2010 | 03:43 PM
  #282
jimbos'ss's Avatar
don't go WOT until you replace or repair the pump. if you take it apart you notice a buildup of carbon, clean that out. if it still doesn't work, replace the motor brushes. if you don't know how to do all that, buy a new one, there only a bill.
Old 04-12-2010 | 03:54 PM
  #283
my pump when out after we installed my Ottp Heat Exchanger, when we were data logging my tuner noticed the IATS 2 were high, ordered a new pump and installed it yesterday and the car is awesome again, no more cruise mode haha
Old 04-12-2010 | 06:02 PM
  #284
chris88z24's Avatar
Where can the brushes be purchased from? Any idea?
Old 04-12-2010 | 06:24 PM
  #285
ItalianJoe1's Avatar
I found them at a local tool repair shop, aparrently they are a standard Bosch part#. I'll do a little research later on to try and find the ones I found.
Old 04-12-2010 | 06:25 PM
  #286
FastSSinNH's Avatar
Does the car need to be running to check for the sound of the pump running or does just the ignition need to be turned to "on"?
Old 04-12-2010 | 06:27 PM
  #287
ForsakenOutlaw57's Avatar
^ awesome sig banner
Old 04-12-2010 | 06:35 PM
  #288
chris88z24's Avatar
The car has to be on unless it's enabled in HPT. My car was tuned with HPT but it still only comes on with the engine running.
Joe I'd greatly appreciate a part # for the pump brushes.
*edit* Apparently CB-407 Makita brushes are a close fit, you just have to sand them down and then splice the wires from the original brushes.
Old 04-12-2010 | 06:42 PM
  #289
Frew's Avatar
Joe I'd greatly appreciate a part # for the pump.
ya enabling it in hptuners is the easiest way to know when its running, thats how I have it, otherewise if you have option be it should be spraying pretty hard back into the fluid reservior
Old 04-12-2010 | 06:43 PM
  #290
FastSSinNH's Avatar
Thank you haha.
Old 04-12-2010 | 07:03 PM
  #291
boost_junkie16's Avatar
Snap-on Verus scan tool ftmfw.. Can turn the pump on and off with the scanner. Turned mine on, put the car on the hoist, hatrickstu hammer mod and bam.. whining and my head covered in coolant haha.
Old 04-12-2010 | 07:07 PM
  #292
I looked up the parts on the website for the company I bought them from, can't find them...
Old 04-12-2010 | 07:24 PM
  #293
Bootz's Avatar
Originally Posted by STS2/SS
Go air to air and never worry again. Also it'll give you the ability to make more pony's. I just started freakta's he's excited! With the stock luminova setup there are alot of flow barriers and bottle necks not to mention at stock boost levels the luminova's heat soak with one hard pull. It's been proven time and time again!!! I built myself a true intake manifold with a three inch thick bar/fin bell intercooler core and redesigned the flow path and I gotta say the AIT2's speak for them selves! But there is still a problem you'll max your cylinder head out and the major bottle neck will then be your exhaust ports..... But I did make a decent 266/258 with a 2.7 and after seven striaght pulls my AIT2 at idle was 109 and on the 8th pull at 7000 rpms it peaked at 138! Fred at SMG couldn't believe it he said it should be so hot right now that it doesn't register on HPT and he touched the SC and it was cool to the touch, his jaw dropped!!!! Awsome.. So we are trying something new with air/air setup but I can asure you that bell intercoolers seems to think it will perform better as a street setup then my liquid/air setup? We'll see.......
Any updates??
Originally Posted by megaman311
After talking with many people and reading many forums... As everyone is aware, this pump is not made by GM. It is Bosch part no. 0 392 022 002
Now, Mercedes, Sabb, Jaguar, Ford, GM, and probably many others use this exact same pump. So why does ours go out? Is there anyone on this site that can confirm the guage of wire that is used? Maybe that is the problem, starving the pump of current. If so, there are many harnesses that you can get with the new pump that comes with 16 guage wire. If this is truely the problem, you can use a 30 amp relay to solve the problem, and still have the computer controlling the pump.
Any takers out there?
Anyone find an answer to these questions as of yet?
*** Sub'd
Old 04-13-2010 | 01:30 AM
  #294
goeckeritz123's Avatar
K I just filled my reserve up and I drove around and it goes down below fill mark is that mean my pump is working
Old 04-13-2010 | 01:51 PM
  #295
Nfangelo's Avatar
How easy is it to take apart the pump and clean it out? any vids? or pics?
Old 04-13-2010 | 02:21 PM
  #296
06cobalt racer's Avatar
well if you just put your he on then it is bleeding out the air which is a good thing.
Old 04-13-2010 | 02:46 PM
  #297
But does that mean my pumps working
Old 04-13-2010 | 02:56 PM
  #298
yeah it should be working. if you just have the filler neck start your motor take the lid off the filler cap and you should be able to see it flow
Old 04-13-2010 | 03:37 PM
  #299
megaman311's Avatar
Originally Posted by nfangelo
how easy is it to take apart the pump and clean it out? Any vids? Or pics?
search
Old 04-13-2010 | 03:55 PM
  #300
Well last night I started it at pulled the cap off and it just shot to the top and stayed their
Quick Reply: LSJ Important Warning!
