LSJ Important Warning!
damn works for me, just go to zzperformance, and then type in pump into there little search feature, should come up as intercooler pumps.
Even if the car is stock, the intercooler pump should start running with the key in the "on" posisiton and the car off. What some people have been doing with HPT is making the pump run when only under accessory power. Just turn the key and you should hear a faint whine under the hood if it's working.
maybe, the only way i figured that out is i took the old faulty pump apart, the plastic shavings are the consistency of dust. the turbine impeller for the pump sits in this cup that basically acts as a journal bearing, it has a magnet in it. on the electric motor there is a magnet on the shaft that spins. if you get the shavings in there the pump stops working or works intermittently.
sounds like a good fail-safe maintenance plan to me...
#37
#39
#40
#48
#50
I dont like this article. It makes me worried that my pump is gonna go soon. Ive been running for about 2-3 weeks with my CX h/e on. Is the filler neck supposed to be filled to the top or is it supposed to be like an inch from the bottom?
