LSJ Important Warning!
#152
thanks a mill!
#154
#155
#162
#163
yay or nay to this mod?
https://www.cobaltss.net/forums/showthread.php?t=68621
#164
#166
Hello Gang, Thank you "Psykostevo"!!!! I opened my hood and looked at the filler neck, saw barely any water/coolant. I opened the cap and rush of air came out and the fluid rushed to ok levels. I started the car(cold) and watched the filler neck, nothing... I looked at the resevoir and couldnt tell thier either. So i looked up info where that damn part is and took a long screw driver to it and tapped a few times. Stasrted the car and bingo, the filler neck is bubbling. Man I wonder how long this has been going on. The car felt sluggish when warm. So I hope this solves that. Ok next thing Psykostevo, whats a good pump to replace this? Thank you for saving my car!!!
#167
#170
I looked at my car, with the car cold there was very little coolant, I'd fill it a little while running, tap it with a hammer, don't know if tapping the thick aluminum casting is the right place to tap, and it seems like for a closed system it can keep drinking coolant with no end in sight weird?
NVM: found plastic side of casing after hitting it with a hammer it seemed to keep its level it was foamy. If the brushes are "soft" why isn't there one with harder brushes or a brushless motor?
#174
