LSJ Sparkplug Question
You can also gap iridiums. You just need the proper gapping tool, and make sure you are careful. I run iridiums and have gapped them many times.
Well you see I bought the iridium 8's because I was thinking my plugs were too hot but after looking at them again I think they're ok where they are. once I start tuning things may change, so I may hold on to them.
It has nothing to do with the injectors, it has to do with the tune. Both stock and gm stage 2 do run EXTREMELY rich. I know of a cobalt on this forum who washed out his cyl walls after a rebuild on a 10ish afr because of an o2 sensor error. Now I am not saying that this will happen to any of the gm builds, however running that rich is NOT good. Hence why so many stock/gm stage 2 cars gain a decent amount of power from a custom tune after leaning out the car.
You can run any injector you want, but keeping the same air to fuel ratio as stock/gm stage 2 has it you are still going to run way way way to rich.
but I digress. this is a discussion about spark plugs, not idc's and tunes. Back on topic....
I think you're exaggerating a tad on the tune there buddy. Not sure about stock, but the stage II tune is set to 10:1 at WOT. Yeah it is richer than these cars like, but not dangerously rich like an 8:1 aft or anything. Keep in mind the money zone for the lsj at WOT is about 11.1-11.3. Certainly not the best tune though. And yes...it has everything to do with the idc. The danger comes in when they can't pump enough fuel into the cylinder and sparks a lean mixture as a result of going static.
I do agree with you though that idc's play a huge roll etc, however not with stock/gm stage 2 cars which is what I was talking about specifically and how there 10 afr at wot leaves a lot to be desired.
Back on topic I am going to grab a new set of plugs, want to see how high I can gap these bkr7e's in the winter time on the tvs before blowout. I am guessing .033 will be ideal for my setup.
This isn't the answer as running these plugs for that amount of time is not ideal. Pull the plug and look at it, you won't like what you see. Once you are around these kinds of things long enough you tend to realize what high temps and over fueling can do to these plugs, let alone for 20k miles.
These motors should not eat plug with proper tuning. No motor should eat plugs with proper tuning.
Try 0.035" first, and see how it feels. If you have no spark blowout it will be a better gap for your application.
0.032" is usually the perfect gap for lower pullied cars, but all cars are different so try some gaps out until you find the best one for your car.
#36
If your car is basically stock I would try a slightly larger gap.
so i guess i need to be safe! LOL
#37
I ran a 0.035" gap for years on my car.
I didnt start experiencing spark blowout until I bolted on my different blower. I tried all the gaps between 0.035"-0.032", and literally chased the spark blowout away. At 0.035" i started experiencing spark blowout around 5,500 rpm or so in 2nd gear. At 0.034" blowout was noticed around 6,000 rpm, and at 0.033" it moved on up to around 6500 rpm. Finally, 0.032" proved to be the best gap. Zero spark blowout, and was the largest gap i could run without issues.
This is why I always try to stress to people not to immediately gap at 0.032". That is not always the best gap for everyone. While it is a very common gap for smaller pulley balts, it wont be the "best" for a fairly stock car.
#39
actually since ive never done plugs before, is there a way i can check to see what my stock plugs are gapped to when i take them out? Car runs fine but im just a noob when it comes to plugs lol.
#40
Pick up a spark plug gap gauge. They sell them for about a $1 at any Autozone, Advanced Auto, etc.
ThoR294
10-04-2015 09:44 PM
09-28-2015 01:51 PM
