Lsj transmission talk
Old 12-04-2013, 08:50 AM
  #51
mongorat427's Avatar
Originally Posted by 574
I thought 4.45s were extinct
Not if you can find a 2000 thru 2003 Saturn L series Trans
Old 12-04-2013, 09:01 AM
  #52
Got Bewst?
Bluelightning's Avatar
Originally Posted by mrbelvedere
its supposed to be stronger also
Ya I heard this too. That's why my buddy went with it. I'm surprised more people haven't done it. You can pick up an F23 for pretty cheap. I'll ask him what all he had to change to make it work.
Old 12-04-2013, 09:02 AM
  #53
noorj's Avatar
You've never driven one with a built trans^
I don't know the guys name but I've seen the car floating around a few times. It's a cavy that has a ton of custom fab work and he's making it into a drag car. I asked him what trans he is running and he said f23..
Any info on what was done to the F23
Old 12-04-2013, 09:13 AM
  #54
alerosaint's Avatar
i looked it up and they say the f23 is rated at 260ft lb but then again the F40 is rated at 295 ft lbs and sythe is running with no issues as far as I know
Old 12-04-2013, 09:16 AM
  #55
mrbelvedere's Avatar
cables and a shifter from donor car is all I believe but the downfall is no lsd stock
Old 12-04-2013, 09:27 AM
  #56
Saturn L series from 02 to 04(I think the years are correct) 4cyl 5 speed was an f35 with a 445 final drive that is what my 445 came out of that I got from mongo
2000 to 2003 to be exact
Old 12-04-2013, 10:08 AM
  #57
mongo is the man
Old 12-04-2013, 10:17 AM
  #58
chris88z24's Avatar
So is the F35.
Old 12-04-2013, 10:20 AM
  #59
Got Bewst?
I just talked to Kevin. Shifter cables, clutch line, front and side trans mounts, axels and he said he had to take the t stat housing off and trim a little off something and weld a flat plate on cause it hit the trans. But he said it was super simple.
Old 12-04-2013, 10:53 AM
  #60
badass
Old 12-04-2013, 11:13 AM
  #61
Got Bewst?
I can pick up a used F23 for $400. Might be a direction to take if and when my trans lets go to test seeing how few have tried it.
Old 12-04-2013, 11:16 AM
  #62
574
574's Avatar
For sure something to look into? Whats the GR on those?
Old 12-04-2013, 11:32 AM
  #63
Got Bewst?
Final drive is 3.84. But gears 1-4 are all shorter than the F35. Quicker acceleration with better gas mileage haha.
Old 12-04-2013, 11:33 AM
  #64
I would do a 445 swap first
Old 12-04-2013, 11:42 AM
  #65
alerosaint's Avatar
So is the F35.
Touché
This is a great thread.
Keep the info going. I was thinking about the f 40 but seems that there are just as good more available options out there. Let's hear more about the f 23.
So the 3rd gear will hold under 400 ft lbs you guys think? Better gas caught my attention as well.
Old 12-04-2013, 11:44 AM
  #66
Got Bewst?
So would I if money wasn't an issue. But it's a cheap and probably much better alternative than throwing in another F35.
Old 12-04-2013, 12:26 PM
  #67
alerosaint's Avatar
An LSDs are under 1000 for the f23
Old 12-04-2013, 12:33 PM
  #68
Josh@ottp's Avatar
I would do an auto trans if it were me.
Old 12-04-2013, 06:03 PM
  #69
chris88z24's Avatar
Anyone ever replace the trans bearings in the F35? Or have them fail completely?
PS - F23 is rated for 170 lb/ft, not 260.
Old 12-04-2013, 06:15 PM
  #70
Pinky Demon's Avatar
Much faggorty in the first two pages of this thread.
Old 12-04-2013, 07:07 PM
  #71
alerosaint's Avatar
So is the F35.
You are right. Thx for the correction
Old 12-04-2013, 10:57 PM
  #72
chris88z24's Avatar
No prob
Old 12-04-2013, 11:09 PM
  #73
nhanson's Avatar
F23 takes abuse well...just need a decent clutch so it doesnt slip.
All the 2.2/2.4 guys i know with somewhat good power have no problems with the F23.
4.45s are plentiful in my area BUT high mileage (but I dont have a LSJ anyway lol)
Another thing is I have fun with my auto...I downshift to hold gear for racing, its really not that bad.
I have pressure up and shift time down so its pretty damn quick on shifts.
Old 12-05-2013, 12:36 PM
  #74
574
574's Avatar
I'm gonna message you on fb. I want a 4.45
Old 12-05-2013, 12:45 PM
  #75
Steviodaddio's Avatar
I have not driven a built auto trans. Would your shift time really improve if you built up your trans? I thought building up one was mainly for holding power, I didn't think it would increase your shift speed. I have never even looked into building up an automatic since I haven't seen anyone around here consider it. Automatics are quick but you shouldn't be too concerned if you're a decent shifter in my opinion at least. Just get a cheap F23 or F35 and cryo-treat it or upgrade bearings, whatever you want to do money-wise. 6 speeds are going to be through the roof. I know KillaSS bought a cheap used 6 speed that's holding up fine with his 252 or 256 build so far but it hasn't been in long enough to really say if it's reliable or not. He didn't do anything to it either, just had ZZP install it the way it was.
Quick Reply: Lsj transmission talk
