Lsj transmission talk
Old 12-05-2013, 12:53 PM
  #76
InfraRedline's Avatar
A built auto will always outshift a manual. You just cant beat a properly setup auto. In an all out drag car, I agree auto is the way to go, but its just not for me.
Old 12-05-2013, 12:55 PM
  #77
WSFrazier's Avatar
I have not driven a built auto trans. Would your shift time really improve if you built up your trans? I thought building up one was mainly for holding power, I didn't think it would increase your shift speed. I have never even looked into building up an automatic since I haven't seen anyone around here consider it. Automatics are quick but you shouldn't be too concerned if you're a decent shifter in my opinion at least. Just get a cheap F23 or F35 and cryo-treat it or upgrade bearings, whatever you want to do money-wise. 6 speeds are going to be through the roof. I know KillaSS bought a cheap used 6 speed that's holding up fine with his 252 or 256 build so far but it hasn't been in long enough to really say if it's reliable or not. He didn't do anything to it either, just had ZZP install it the way it was.
Until you drive a race built trans with a manual valve body, up'ed line pressure, etc... you haven't driven an automatic.
I've been in some autos that really slam the gears. Faster than any manual ever will.
Old 12-05-2013, 01:00 PM
  #78
taintedred07's Avatar
Money is pretty much the limiting factor at that point
Old 12-05-2013, 01:05 PM
  #79
574
574's Avatar
I've gone back and forth from all ideas 4.45 f40 and built auto. This is what I've decided.
Built auto: Fastest on the track, unsure about DD'ing it.. would be badass because no one does this route
4.45: shorter gears= less stress, fairly inexpensive. Poor mpg, faster acceleration.
F40: expensive, holds a ton of power, haven't heard of one broken yet, 6th gear for good mpgs.
I guess for a dd the best option seems to be the F40...
Old 12-05-2013, 02:33 PM
  #80
alerosaint's Avatar
How much an f 40 will run with an lsd?
Old 12-05-2013, 02:42 PM
  #81
574
574's Avatar
3 something go to zzp and price it
Old 12-05-2013, 02:46 PM
  #82
Pretty sure they don't off it with lsd, you'd have to purchase your own kit
Old 12-05-2013, 02:50 PM
  #83
574
574's Avatar
Didn't know that. That sucks
Old 12-05-2013, 02:56 PM
  #84
That's a con of f40, I think there's a quaife kit for $1500 or something, it adds up
Old 12-05-2013, 04:29 PM
  #85
nhanson's Avatar
Its nice to be able to just put my foot down and GO.
Traffic is a plus too
Maybe once my car is running ill get a vid of the shifting of my car
Old 12-07-2013, 01:52 AM
  #86
Steviodaddio's Avatar
Touche. Would be interesting and I definitely believe you.
Old 12-07-2013, 02:46 AM
  #87
slitterell's Avatar
Auto shifts way faster. Then, you can run a transbrake, Launching is easy. You can't out launch an auto on t brake and you can't out shift it so it is tough to beat. You turbo guys would love it
I am in for more info. I am not purchasing one now but will be in the market soon and it will be good to get info before I do.
hypothetically, wouldn't lwrs work on the pcm open up the capacity to run an auto?
Old 12-07-2013, 09:15 AM
  #88
mrbelvedere's Avatar
you don't run a trans brake on a street car and you don't need it to launch an auto car either
Old 12-07-2013, 10:41 AM
  #89
lsjion's Avatar
You know what's the best idea for a DD big turbo car?
A daily driver. In all honesty, you shouldn't even be considering how good/bad gas mileage it'll get.
A daily driver is cheaper and always a must when you've built something that doesn't belong on daily duties
Old 12-07-2013, 10:54 AM
  #90
BlkWdoSS's Avatar
Not always but for sake of this argument, most of us wont ever be able to afford a manual that does outshift an auto
Old 12-07-2013, 10:56 AM
  #91
an auto will always shift faster then a stick
Old 12-07-2013, 11:07 AM
  #92
andrewcarr1993's Avatar
I'll assume he's thinking dogbox but those are still slower.
Old 12-07-2013, 11:15 AM
  #93
South Central *********
JapEatr's Avatar
Idc about mileage.
I want the 4.45 for the third and 4th gear pulls to 8k
Old 12-07-2013, 12:29 PM
  #94
BlkWdoSS's Avatar
Shift times / shift speed for transmissions including automatic, DSG, DCT, SMG, SMGII, dual clutch, manual, etc.
The fastest automatic in the world is the Lexus IS-F gearbox, at 100 ms. The ZF transmission in BMW's is at the 200 ms mark.
and if those dont count because they are paddle shifters then the NHRA Pro Stock manual transmissions are still lever actuated and are in the top manual transmissions in the world in shift time.
Old 12-07-2013, 12:37 PM
  #95
nhanson's Avatar
I have my auto set anywhere from 150-200 ms depending on what shift its doing.
Old 12-07-2013, 12:45 PM
  #96
chris88z24's Avatar
I want the new Chevy SS but not sure if I should wait for the manual or not.
Old 12-07-2013, 02:06 PM
  #97
Wait for the manual, you'll probably regret not and they normally work out some issues with them in the first year even if their mainly just a Holden rebadged.
Old 12-07-2013, 03:06 PM
  #98
chris88z24's Avatar
I was thinking the same. Maybe they'll even put the new LT1 or the old LS7 into it for a limited run. That would be epic.
Old 12-08-2013, 03:17 PM
  #99
shadowfaxss's Avatar
Are we talking about an automatic for street driven daily use or a full race setup? I agree that the above mentioned transmission should not be included from the aspect that they do not use a torque converter but rather an actual clutch disc. However, if my Cobalt SS/SC would shift as fast as my e63 M6 with paddle shifters and can be driven as a daily driver I would consider it.
IMO, automatic has always been great for straight line racing and the manaul for the road course. I have seen many manually shifted transmission spank an automatic on the 1/4 mile though.
All preference. I prefer the manual over a torque converted automatic transmission. The manual is what makes the SS a fun to drive car.
Old 12-08-2013, 09:03 PM
  #100
63 Nova SS's Avatar
subd for later
Quick Reply: Lsj transmission talk
