Lsj/tvs engine build #2
Long story short; first forged engine build with a tvs shot a LSJ rod out the side of the block. /THEEND
It's your basic forged rebuilt with some minor tweaking.
Gen 1 Block
MrB Sleeves
Tjolley Upper cylinder sleeve support girdle
arp timing component bolts
ATI overdrive dampener
Stock HG - ARP head studs
Diamond 10.5:1 Pistons
Molnar H beam rods
LSJ crank - extended keyway
Balance shaft delete
Electric Water pump
Balanced rotating assembly
LSJ ION Ported head
Supertechs
Stock valves
TVS 1320 (sorry no 1900 for now)
nitrous wet shot (progressive hit)
ZZP LT, CATBACK
ZZP CAI
Gen 1 Block
MrB Sleeves
Molnar H beam rods
Electric Water pump
LSJ ION Ported head
Supertechs
Stock valves
ZZP LT, CATBACK
ZZP CAI
Sub'd. Glad to see you didn't give up man but came back stronger.
The upper cylinder supports is a great idea! Something to keep in mine when I build this motor I got sitting here.
Probably not for a good while. Tjolley will probably. Get one on his 2.4 build long before me
That was the idea
Figured since I had to sink another 2k in parts again. I wanna feel 2,000 bucks, not meh it's fast and spins 2nd.
Well either way Steve I'm glad to c its getting finished! And good to know tjolley u have access to stuff. Will definitely be using ur skills in the future.
The tvs1900 is the next sc I slap on my car when I get bored with the mp90. Though it has to go on first to get bored of it. Lol
Two years and you still haven't installed it
You know it bolts right on right?
Just install it already , drive it over and we can tune it.
Worry about the ported head later
Magnusun is not far from LA. That's a plus.
It hasn't been 2. I know I could but want to wait for everything else. Just take it all off. I don't have access to all the tools and garage space all the time so wanna make it count. I stil need to get the taps from Rodney for the meth. I know I'm lazy. But have other things goin on (carbon)
