Lsj/tvs engine build #2
Old 09-12-2013 | 11:28 PM
  #101
JapEatr's Avatar
South Central *********
Where you gonna add the wieghts?
Old 09-13-2013 | 03:14 AM
  #102
100% METH's Avatar
Originally Posted by Tjolley
Lmao guys come on now.
Steve Wen u Wana balance Ur blower. Im getting mine done as soon as my 2.4 pulley shows up.
You just want to play with my TVS...
Old 09-13-2013 | 07:05 AM
  #103
Tjolley's Avatar
Idk how my guy dose it.
He was balancing Steve's wrist pins Wen i went the shop to talk to him about doing the blowers cuz i will be turning mine somewhere around 22,000+rpm
Old 09-13-2013 | 07:06 AM
  #104
Tjolley's Avatar
Maybe!!!!!!! Lol
Old 09-13-2013 | 01:12 PM
  #105
SSfamilywagon's Avatar
Mmmmmm I didn't know you can balnace the blower!! Interesting
Old 09-13-2013 | 10:03 PM
  #106
mrbelvedere's Avatar
Why, you interested?
only for you tigre man GRRRRRRRRRRRRRRRRR GRRRRRRRRRRRRRRRRRRRR
Old 09-21-2013 | 07:34 PM
  #107
Tjolley's Avatar
Old 09-21-2013 | 08:45 PM
  #108
Melon's Avatar
And I just came
Old 09-21-2013 | 08:55 PM
  #109
Tjolley's Avatar
Old 09-21-2013 | 09:16 PM
  #110
Powell Race Parts's Avatar
^^^ questions: any reason not to get coated diamond pistons? is the IM media blasted? what piston rings did you choose? what caused the broken pivot?
Old 09-21-2013 | 09:44 PM
  #111
Tjolley's Avatar
Well Steve didn't want the coatings. I personaly would have at least gotten the side coating.
Yes the IM is glass bead blasted. I taped off the ports and all that.
We chose conventional rings.
I do not know y the lifter broke. I think the piston hit the valve and the lifter was the weak point. It bent every valve in number 3 cylinder.
Old 09-21-2013 | 10:00 PM
  #112
i love the coatings. wish the IM would stay nice. conventional rings suit me but it takes a long time for oil control rings to seat. Not sure what I would suggest for that, may build another engine differently. Yup hydraulic pressure on the lifter from that piston hitting valve etc would be extreme and break the lifter easily enough...
Old 09-21-2013 | 10:08 PM
  #113
Tjolley's Avatar
Bead blast it and have it clear powder coated. Then all it takes is a good hose down.
My whole 2.4 is powder coated like the time attack i think was. And i just picked up a Tvs 1320 that im Gona strip have balanced and polish possibly.
Old 09-21-2013 | 11:04 PM
  #114
you don't need to strip the rotor pack and have it balanced eaton does a fine job
Old 09-21-2013 | 11:05 PM
  #115
a lot of it is in the hone and what type of 2nd ring used
Old 09-21-2013 | 11:20 PM
  #116
Tjolley's Avatar
I just Wana have it check before i spin the hell out of it.
Old 09-21-2013 | 11:34 PM
  #117
sometime you need to learn when to leave stuff alone
Old 09-22-2013 | 09:50 AM
  #118
^^^troof.
Old 09-22-2013 | 01:15 PM
  #119
Tjolley's Avatar
Ya true but i Wana have it check. Its worth the pice of mind to me. And plus its only like 60$ to have my guy do it.
Wen i asked him he said u would be surprised how far out they can be after they r used a while.
Old 09-22-2013 | 01:43 PM
  #120
im going call bull **** on that
the only way the rotor pack wears is if the case needles are shot and cause contact and then it would have to happen over a long period of time not to mention your going to have to untime the rotor pack to check and upon retiming and repressing the pack back together is where the damage will occur just leave it the hell alone and run it
Old 09-22-2013 | 02:33 PM
  #121
armcclure's Avatar
Why didn't I get invited to the party? And good luck re-timing a rotor pack.
Old 09-22-2013 | 04:06 PM
  #122
I keep agreeing with Mr. B. wow.
Old 09-22-2013 | 06:18 PM
  #123
armcclure's Avatar
You two are both stubborn old men. But when you're right, you're right!
Old 09-22-2013 | 06:57 PM
  #124
you two are both men. But when you're right, you're right!
fify
Old 09-22-2013 | 08:04 PM
  #125
100% METH's Avatar
Cool build ..
Op is one lucky sob
Quick Reply: Lsj/tvs engine build #2
