LT1 Maf
LT1 Maf
Just wondering what the benifit would be to running a LT1 maf vs the stock maf? I tried to msg fast but his limit is exceded.
Any info would be great
Thx
Thx
So I can run a custom 3" intake or even maybe a 3.5? It will allow the S/C to suck air better, maybe resulting in less heat soak as it wouldn't have to work as hard?
I dont think that would help much or at least it would be a waste of time and money.
Your supercharger can only such so much after that its pointless. besides the lt1 maf would more then likely be more retrictive the the stock sensor.
The lt1 maf is much less sensitive that the stock maf sensor. yes you could create your own intake. I don't know how much it would help with heatsoak but in theory it should help.
Originally Posted by Bad06SS
Wow. You sound just like the techs at our dealership-clueless. No offense. The LT1 maff is actually bigger, so it will flow just fine, probably more. More importantly, the stock maff is just too sensitive. The LT1 maff is alot easier to tune with. Rob and I are using this with a custom 3.5" intake.
From a fellow tech, that statement makes me want to BARF
Lets see,
Stock maff OVERLY sensitive to ANY changes, only 3"id, pegged at 10K Hz
LT1 maff, Very durable and predictable, 3.5" id, i now get 9300 Hz which leaves me room to grow.
The easier it is to get air to the SC the less it has to work to suck the air in. PERIOD!
Pat,
The stock table will get you running and you only need to fine tune from there. I had to adjust slightly to get me LTFT's + or - 10 You'll like it!
Originally Posted by FAST06SS
Pat,
Originally Posted by StinkBOMB
Why not use the LS1 maf? Or an LS2 maf, or are they all the same thing?
The LT1 maff already has an IAT sensor in it.
The LS1 NOT the LT1 has the IAT. Thats why we have to add one Kevin.
As for not using an ls1 maff, logistics! They are 2 different sizes and require extra adapters which add to the overall cost.
so when you guys say that the maf is super sensitive in the lsj.. and something about 10000hz.. what does this mean, like you say the lt1 is less sensitive at 9300 hz, what does this accomplish, how does it help when tuning the lsj? how do you tune it? etc? maybe a faq for this would be good?
