MAF Tuning adjustments for 3" intake
Tuning the maf for a 3" intake seems to be a tedious task, any adjustments seem to swing one way versus the other
Anyone specifically tune for larger intake also have these same issues?
Also what histograms did you use. I set up one MAF Freq vs LTFT+STFT and have been trying to get the trims in check but AFR seems way off
I have a 3" intake for 2 years with ls4 tb. Local came over and changed the parameters in my driveway for the intake only as the ls4 was already changed and has run fine since then.
Pm me your email and I can send you some of my tune files from a couple years ago.
Tune file will be on 42's, 2.8, ls4, 3" intake, header, catless 3" dp, and stock catback.
im having issues correcting MAF swings for Hockeyman's Ported Head/Stage 2 Cams/3" intake/Longtubes/M62 2.8/80#s/E85
STFTs wing from +5 to -7%
its not bad, and i think his long tube header with cracked flexpipe may be giving erraneous AFR readings at his WB
The stock intake is angled before the MAF sensor. Changes in intake velocity can occur because of this.
Oh ok. My header has had a crack for a few years but never effected anything besides the sound that only a car person can tell. Must be the leak cause I wasnt even charged to adjust for the intake which took all of 5 mins.
