Making Speed!?
Making Speed!?
I am wonder'n about this... Knowing what components make the Stage II n' all. Can I just get like a smaller pully say this.... http://www.zzperformance.com/cobalt_...=613&catid=142 and buy a STage II belt http://www.crateenginedepot.com/stor...P1592C196.aspx and throw in some injectors. Along with HPTuners? Wonder'n if I can do that. LIke that pulley looks really cheap. hrms... Is there something about that pulley I'm not gett'n? or is that a legit pully.iono.. well any info would be helpful.
you need one of these.
http://www.zzperformance.com/cobalt_...=446&catid=142
2.9 is the smallest you can go with 42 lb./hr. injectors
you need one of those for $100 because it comes with the new hub that your pulley will bolt up to. if you look under your hood, you will notice that the stock pulley is a press on pulley, therefore has no hub for the new pulley to bolt to.
you might say "that sucks" that you have to spend a little more for the Modular Pulley System.. but it will be totally worth it. Plus it makes future pulley swaps a breeze.
Last edited by chevysalesman614; 06-21-2007 at 12:05 PM. Reason: Automerged Doublepost
Thanks ChevySalesman614. I was wonder'n what was up with the price of those pulley's. Ight.. what #Injectors are the stock ones? And you wouldn't need a tune with a 2.9 pulley and 42 lbers.? would you?
ThoR294
10-04-2015 08:44 PM
