which meth kit?
http://cgi.ebay.com/ebaymotors/AIS-S...mZ110269575906
Well lets hope a non-progressive kit works because that is what I got. If anything, I could see just raising the boost pressure that it activates since mine isn't progressive. I can't see that being an issue.
How effective are these kits when just spraying 100% distilled water?
AIS i still cheaper even shipped and comes withc a 2 qt tank its about 268 shipped and 50$ fills my car with gas lol
its really personal preference past the pump...i myself have coolingmist...innexpensive kit...does the trick. as for whether or not it compares to a cx h/e... to me thats kinda like apples to oranges since the water/meth is only on past a certain set psi...and it REALLY helps to cool down internals as well as intake charge (among other wonderful properties - ie octance enhancement), whereas the cx h/e is always being used technically and helps to drop iat2's down even when cruising...something that water/meth does not do....so both compliment eachotehr quite nicely.
Yeah. I have washer fluid at home that my dad got from the dealer (it comes in a 55 gal drum) and it burns if you throw a match to it, so its strong. Should be atleast 50/50 if it burns. I could run that but it will just make me richer than I already am. I was going to run water for the time being then throw a mix at it once I can get a wideband and tune it correctly on it.
