meth pump and nozzle question
I was piecing together my own kit and was looking at a 45psi pump. I realize this is much lower than the pumps that devils own and AIS use (150psi). however, if i match the nozzle to the output of the pump, 3gph nozzle rated at 45psi, will i still end up with the same delivery as the kits using the 150psi pumps and nozzles rated at the same psi?
cliffs notes:
is a 3gph nozzle rated at 45 and spraying at 45psi going to net me the same amount as a 3gph nozzle rated at 150psi spraying at 150psi?
cliffs notes:
not really worth it to peice a kit together. i kinda did that, ended up costing me more than the kit. thing is you need fittings and hose that will stand up to methanol, a lot of the stuff you will find is designed for gas (co2, compressed air, o2, ect) and wont hold up with meth. methanol, even in a 50/50 mix is corrosive and stuff just needs to be up to par with it.
i highly recomend devils own, thats what i have and it works great.
Non Authorized / Non-Supporting
http://www.alcoholinjectionsystems.c...icle_info.html
