meth vs heat exchanger
Old 05-19-2009, 03:00 PM
  #76
lsjwannabe's Avatar
You do heat soak at idle becuase your h/e (containing your i/c fluid) is not getting any airflow through it to cool it down allowing temps to rise. Your blower can get heak soaked after back to back to back runs for sure.
Old 05-19-2009, 03:08 PM
  #77
Zach06CobaltSC's Avatar
I don't see how you can get heat soaked at idle. By the definition of heat soaking we shouldn't be able to heat soak unless our car is off, but by the definition we use I still don't think its heat soaking at idle. It's just a lack of air flow causing the iat2's to rise when were at idle. When we do back to back to back runs and then idle we are soaking in all of the heat that we created, but if we are stopping air flow causing heat to be created and then we continue to idle that seems like just a lack of air flow, i guess it could be heat soaking too though. I dont know if that made sense to anyone else but it kinda made sense to me lol. It's basically just how you look at it and what definition you are going by of "heat soaking".
Actually it does make sense that you can heat soak at idle if your idling for a very long time. Because the lack of air flow is creating heat and your just sitting there soaking up that heat because your not moving. You would have to be idling for quite some time though to raise your iat2's up a lot, and it depends on ambient temps and what type of cooling mods you and what kinda i/c pump your using. But ya I should correct myself you can heat soak while at idle.
Last edited by Zach06CobaltSC; 05-19-2009 at 03:08 PM. Reason: Automerged Doublepost
Old 05-19-2009, 03:13 PM
  #78
Tennpenn83's Avatar
that is exactly what heatsoaking is. just another definition of it. you are also correct when you previously quoted that heatsoaking is when the engine is off and there is a rise in temperature.
at idle, the intercooler pump is still running (as long as the pump is still good ) and the fans behind the radiator may or may not be running, depends on your tune. but the biggest factor in cooling down iat's via the heat exchanger is the airflow created when you start driving. you've got hpt, no? do some scanning on what i just said and see for yourself
Old 05-19-2009, 03:16 PM
  #79
I am a tuner so I do have hptuners, I know iat2's rise while idling I just didn't really see that as heat soaking. Generally when I think of heat soaking I think of doing hard pulls back to back and the iat2's being higher from it, and then soaking in all that heat while at idle or cruising *until temps go down again*. That is usually what I think of and most other people for that matter.
Another thing to point out then would be that NO cooling mod will help against heat soaking at idle. The heat exchanger, the dual pass end plate, meth, nothing will help when your at idle because there is no air flow.
Old 05-19-2009, 03:17 PM
  #80
lsjwannabe's Avatar
a killer chiller does :P
Old 05-19-2009, 03:23 PM
  #81
haha good call but that mod doesn't count as it uses up all my good r34a lol.
edit: do you know by any chance how long you can run the k/c before you run outta r34a?
Last edited by Zach06CobaltSC; 05-19-2009 at 03:23 PM. Reason: Automerged Doublepost
Old 05-19-2009, 03:24 PM
  #82
lsjwannabe's Avatar
Its not to bad on it really, does use more but you have to refill eventually anyway
Old 05-19-2009, 03:29 PM
  #83
ajjaro's Avatar
im not sure if this is true or not but when running meth at WOT does a flame pop out the muffler when shifting quickly?
Old 05-19-2009, 03:30 PM
  #84
lsjwannabe's Avatar
It can
Old 05-19-2009, 03:32 PM
  #85
ajjaro's Avatar
what causes this?
Old 05-19-2009, 03:46 PM
  #86
High egt's are one cause of it lol.
Old 05-19-2009, 04:02 PM
  #87
light'bolt's Avatar
and about 80% meth....
Old 05-19-2009, 04:56 PM
  #88
Tennpenn83's Avatar
this you are correct. the dual-pass and heat exchanger and meth will all help to recover quickly from heatsoaking, unless you have killer chiller...
Old 05-20-2009, 09:12 AM
  #89
daythecountrydied21's Avatar
How's the warning lights work for a bad pump if you don't have the progressive controller? Don't have one?
Old 05-20-2009, 09:27 AM
  #90
Stiner's Avatar
Single pass + heat exchanger then decide if you need meth
Old 05-20-2009, 10:13 AM
  #91
ShortStack's Avatar
If your planning on pushing the car, Id get it anyway.
Old 05-20-2009, 11:12 AM
  #92
+1 if you want the most out of your car meth is the way to go!
Old 05-20-2009, 11:16 AM
  #93
Mnatvyc1223's Avatar
i dont know if it's been said, but stay 2.8 or above dude... no reason for anything lower. anything lower than a 2.8 starts to cause the blower to produce more heat and god know LSJ's love heat... cooling mods or not stay 2.8!
Old 05-20-2009, 11:31 AM
  #94
KillinKrullin's Avatar
The devils own kit has error lights on the controller. You can also get a tank fluid level sensor and wire it up to an led light like I did.
ive been meaning to do this.... can you send me a pic of where you installed it? i just wanna see what yours looks like.
thanks,
EDIT: fixed quoted post
Old 05-20-2009, 11:32 AM
  #95
You have been meaning to do what? I think you grabbed the wrong quote lol.
Old 05-20-2009, 11:37 AM
  #96
BAH i hit quote on the wrong post.... i ment the fluid level LED installation
Old 05-20-2009, 11:48 AM
  #97
Grab a tank fluid switch from ottp and then run it to an led mounted in your a pillar =D.
http://www.ottperformance.com/Meth-I...duct_info.html
Thats whatcha need mate.
Last edited by Zach06CobaltSC; 05-20-2009 at 11:48 AM. Reason: Automerged Doublepost
Old 05-20-2009, 12:39 PM
  #98
well i know what i need but i wanna see a picture of where you installed the LED, im trying to figure out where i want it, and what looks best as well as grabs my attention the best.
thanks
Old 05-20-2009, 01:23 PM
  #99
lower with pulleys on meth = torque bud.
Old 05-20-2009, 01:27 PM
  #100
ShortStack's Avatar
It sure as hell does...
You would be worry about peak hp sticking with the 2.8, which is good in some conditions.
Some people like the heavy torque on the bottom end to sling themselves out of corners and pick up where everyone else is leaving off.
Quick Reply: meth vs heat exchanger
