Meziere IC Pump Install
I tried to post a How to on the install of a Meziere IC pump, but it has not been accepted yet. I was wondering whether any of you were interested in how i installed it.
This is the pump i installed.
http://www.jegs.com/p/Meziere/750520/10002/-1
Does anyone know how long it takes to get the how to approved? Or if they don't approve it, do they not tell you that it wasn't approved or not?
I have added a few pics of the install below. It does take time, but this pump is 3 times more reliable then the stock unit, which was the main reason for doing this in my head. I have only heard a lot of you guys complaining about the stock pump failing every year and in some cases even more. I really can't compare the pumps to a before and after, because i didn't have my interceptor gague until a few months ago, which is the reason i found out that my pump had failed.
I am runing a 2.8 pulley, option b kit, dual pass end plate, headers, down pipe with high flow cat, magna-flow cat-back, mustang dyno tune, injen CAI. when i am cruzing at 65-75 i am seeing a 25 degree difference between iat1 and iat2. When i really punch it for long periods of times, it makes it up to a 50 degree difference. I haven't really gotten it over a 50 degree difference between the two temps.
Overall, how much did you spend on this project(if you don't mind me asking)?
And I see anywhere from 10-20 degree difference when driving 65-75 mph with my new pump. It's not the same brand. It's a bosch pump that came off of a ford lightning(the same pump that come stock on SS/SC).
What kind of pulley do you have?
You can't use the stock mount because this pump can only be mounted upright. I drilled two holes into the engine support right beside the Tranny mount. I wanted to reuse the existing mount, but i couldn't because of the way the pump mounts. I wanted the water flow to be as straight through as possible. If i used the existing holes, my tubing would have had to make an extra loop instead of going directly into the stock intercooler.
I'm being very modest when i say 25 degrees difference between iat1 and iat2. It goes down to 15 degrees, but thats when your on the gas a little bit. We all know that when you let off the gas, the temps go up. I'm just one of those guys who doesn't want to post crazy numbers. If i am accelerating the whole time, i can get it down to 15 degrees difference. but i am figuring an average of 25. Plus the reliability of this pump is way better then stock.
I may as well quit writing anything on here. I'm just trying to help out, but there are always people on here that act like little kids and post little bitchy responses like this one. Why don't you just keep that to facebook and keep the drama out of the car forums.
all i know is that i had 2 bosche pumps fail in one year, both were brand new. the first the dealer replaced under warrenty, the other i replaced with the meziere. when i did my research, i found hundreds of cobra/lightning guys who swear by this pump, some racking up 100k miles and over 5 years with them without any issues.
