motors out
the reassembly of the motor started today.all machine work is done the head has been ported and polished.ported the short curve and polished everything up.got a couple of pics they were taken on my phone so sorry for the bad quality. all the parts are in except arp headstuds.using clevitte bearings.the pistons were custom made by JE
https://www.cobaltss.net/gallery/files/6/3/7/1/port.jpg
https://www.cobaltss.net/gallery/files/6/3/7/1/jes.jpg
https://www.cobaltss.net/gallery/fil.../7/1/port1.jpg
the head was hand ported at victory engines in cleveland
i will be doing some cooling mods.probably dual pass w opt b and meth inj.i like the hatrickstu mod but id make it all out of stainless tubing w a ss resavior. im also workin on making a co2 bar for the intake mani not sure if it will be beneficial yet or not but worth a try i fiugre.
the pistons are 9.5:1
Haz l33t wheelz.
co2 bar INSIDE the intake manifold? that would be interesting....
actually diddnt think 2 put it inside the mani but thats not a bad idea ill see what i can do .i already have a couple ideas how it could be done
Haz l33t wheelz.
well, since you're a pipe bender, i'll be watching your metal "hatrickstu" mod haha, might need you to meake me a kit, seeing how it works out.
i don't know how much your engine would like co2 being injected into it...
my wnot throw a co2 bar on the front H/E if/when you get one?
if everything works out with the routing of the tubing i am more than willing to make mor for whoever may want one. i already have the routing figured out once the motors back in the car i will start bending.
ya prob wouldnt like the co2 inj. my original plan was to make aco2 manifold that would be mounted on the outside of the intake mani.about 3/4" off sprayin at th mani. think it would help any?
Haz l33t wheelz.
it might, but not much, the intake mani isn't exactly thin, and although it may make a difference, i just don't see it making a lot. then again, i would have to know the flow route inside the IM and although i've seen pictures, i would need to see it in person, or see a diagram cut-away to know for sure.
well the motors still not back in the car. i have been working in houston for the last month and havent had any time to work on it.my transmission needs some work still. i broke a few teeth on the ring gear ,bearings are shot,mainshaft and 1st gear also no good. so my dad took apart my back up tranny and the parts i need out of it are ok.
im going back out of town tomorow again for work. only gone for the week so hopefully when i get back my tranny will b ready and i can start dropping it back in.
ThoR294
10-04-2015 08:44 PM
