Moving to a 2.9
Moving to a 2.9
After seeing a bunch of people on here running a 2.9 in pulley it has really caught my interest. I have a gm stage 2. Is it really worth using a 2.9in pulley?]
I guess the big question is, is there a big benefit from running a 2.9 on a stage 2 setup? With the 42lb injectors, stage 2 belt and tune?
I think most of the pulley makers make pulleys for the GM hub. Do a search for Nate's pulley. I have the 2.9 on GM stage 2 tune and no issues. 16 psi and runs good.
Yeah, GM stage tune is rich and pretty much has the injectors maxed as is. Throw on a 2.9 and it will just max them out more because it's tuned for a certain AFR. Though I had a Nates 2.9 on 42's for a while without a problem.
I just wanna make sure I am understanding this right. Because I used to be under the assumption that with or without a tune, 42's were going to be way past injector duty cycle.
I'm too JDM for you
Question, making sure I do understand all of this correctly....I'm running the same thing he wants. GM Stage 2 plus 2.9. Now, with the GM stage 2, my injectors are at ~100 duty cycle. But that is because the GM Stage 2 tune runs rich, right? If so, that means I can go out and lean the car up a bit with HP tuners which will drop my injector duty cycle to, we'll say as an example 90 percent. Make sense?
Yea....Well, after all my cooling mods I was contemplating going up to 60's and maybe a 2.8. Not really sure if there will be a noticeable difference between a 2.9 or 2.8 with 60's and a tune. I would also like to somewhat prolong the life of my supercharger....lol
i don't think small mods are really noticeable on the 2.0. anyone that can put on an intake, exhaust, one size smaller pully, etc. that thinks they can feel the difference between 240 whp and 244 whp has one hell of an acurate butt dyno.
when i went from a 3.0 to a 2.8 i checked my logs and it was almost identical the increase.
Well, when I get to that point I'll let you know and we can drive down to Miami for a tune day or something. Meet half way cause I have had 0 luck finding someone here....lol
i just put on my 2.9 from nate and i like it a lot, but im hitting like 15 psi? which i think its because i have a larger throttle body i ported my inlet side of the supercharger, and i have a catback. because before the 2.9 i was only seeing like 12.5. we will see this week when i get my interceptor. and if you swap pulleys good luck with those blue screws mine were rediculous!!!!!
DANRICKARD
10-01-2015 12:08 AM
