A must have for EVERY LSJ
Old 08-31-2011, 08:11 AM
Superbalt06's Avatar
I have a Magnus one for my eclipse. I was surprised they worked so well. After that a
and cutting out my front mount whole I lost like 12* according to my logs. I still don't have any heat shields so that would probably help even more.
Old 08-31-2011, 08:18 AM
zrated89's Avatar
Frew the bolts should be used. The two inverted torx studs in the center are too short and u would only be able to thread the nut a few times. They would probably strip out when u torque them down. And the other remaining studs would only go into the head an eighth of an inch. Just use the bolts theyre actually nice quality ones as well. I would be worried about the oem ones pulling threads out.
And i too in va would have ambient temps of 100+
Old 08-31-2011, 11:01 AM
freakta's Avatar
nice to see some more cooling mods
Old 08-31-2011, 11:20 AM
blake05SS's Avatar
very good info here good job zrated89
Old 08-31-2011, 11:30 AM
nizzle's Avatar
Quick question. When I did my dual pass I did not have to take off the alternator or even loosen the bolts for it. Same with the ic pump. Do I have to take loosen or take of the alt and ic pump to do this? Or can I just get my intake off like I did with the dual pass?
Old 08-31-2011, 11:49 AM
rivaladore's Avatar
You need to remove the ic pump bracket in order to install the spacers. By all means if you can get to the elusive bolt without removing the alternator then big props to you
Old 08-31-2011, 11:54 AM
nizzle's Avatar
It was a while ago but I really dont remember removing any alt bolts
Old 08-31-2011, 12:05 PM
klloyd's Avatar
It's like this mod just blew up recently. Never heard of it, read one post, ordered and installed now every one is doing it. I put mine on 2 weeks ago and have yet to drive it more than 2 miles at a time(live and work on base) but the temps are so much lower now. My car never had the lower manifold bolt so it was even quicker for me to install. But $99 for temps like this, worth every penny!!
Old 08-31-2011, 12:30 PM
Frew's Avatar
I bought mine off tennpenn(jordan) no zzp, so I don't have thse bolts, ill just go to the hardware store and pick some up
Old 08-31-2011, 01:07 PM
rivaladore's Avatar
I contemplated getting the spacer for about a year, didn't think it was going to work so well because no one ever said anything about it. I put it on and was amazed at the temp drop so I made a review thread and now here we are.
Old 08-31-2011, 01:08 PM
  #36
rivaladore's Avatar
Don't forget about 3 spacers for the lim/ic bracket
Old 08-31-2011, 01:09 PM
  #37
nizzle's Avatar
So it's like a kit? More than a spacers for the IM and bolts? spacers for the ic pump too?
Old 08-31-2011, 01:22 PM
  #38
rivaladore's Avatar
The lower intake manifold bracket and the intercooler pump bracket are attached to each other. Two of the spacers are for the lim bracket and one spacer for the ic bracket. Once you take everything apart you'll understand
Old 08-31-2011, 02:17 PM
  #39
zrated89's Avatar
Nizzle u must be dam flexible if u took the 15mm bolt out of the lower manifold without taking the alternator loose. Its worth the three bolts for the alternator to access it lol
Old 08-31-2011, 02:20 PM
  #40
zrated89's Avatar
Yes u could piece together the hardware but zzps comes as a kit with the spacers for the bracket as well. U can see them in my pics
Old 08-31-2011, 02:21 PM
  #41
zrated89's Avatar
your review prompted me to get mine i just figured id take some pics for members on here. I seen a few people that werent installing it right
Old 08-31-2011, 02:32 PM
  #42
Administrator
Administrator
Staged07SS's Avatar
How are the temps after a WOT run??
Does it make any difference there?
Old 08-31-2011, 02:50 PM
  #43
nizzle's Avatar
Maybe I did. cant remember
Old 08-31-2011, 04:06 PM
  #44
sternerG85SC's Avatar
sub'd future mod
Old 08-31-2011, 05:19 PM
  #45
TTown SS 63's Avatar
This will be a future mod for me because of this thread
Old 08-31-2011, 07:08 PM
  #46
euthanasia's Avatar
Getting one soon thanks Z.
Old 08-31-2011, 07:28 PM
  #47
Frew's Avatar
Maybe ill just sell the one I got and pick up zzps kit
Old 08-31-2011, 07:49 PM
  #48
zrated89's Avatar
yes but more so because youll have cooler ita2's to begin with. i just got my meth up and running again with the 10gph nozzle, after i do a pull with a starting temp of 88 iat2 after the run all through fourth i was seeing like 120's on my 2.7. Then after of course they would drop instantly. (at the strip when i ran my 13.1 @ 107 my iat2's were 160's at the trap and that wasnt even coming out of third!!) Its more for idling in the staging lanes or at a drive threw where it shines because it keeps the heat transfer from the cylinder head to the manifold and blower at bay
Old 08-31-2011, 07:51 PM
  #49
zrated89's Avatar
or just get bolts that are a quarter of an inch longer than your stock ones. but youd have to go to the hardware store after pulling the manifold
Old 08-31-2011, 07:53 PM
  #50
zrated89's Avatar
i should be thanking you jr
car feels better without even retuning her yet shes loving these iat temps
Quick Reply: A must have for EVERY LSJ
