A must have for EVERY LSJ
Old 10-01-2012, 10:47 AM
  #151
insylem's Avatar
Originally Posted by Frew
. Highest i saw my idle iat2s was 160* terrible. I got one of these sitting in a box at my house, I might put it on now haha
Sure your IC Pump is working?
Old 10-01-2012, 10:51 AM
  #152
insylem's Avatar
Originally Posted by zrated89
ZZP Changed their websight arround,
Here is the new link for any who are looking to buy.
ZZPerformance - LSJ Phenolic Intake Spacer #MT-LSJPHNSPC
Old 10-16-2012, 10:56 AM
  #153
hoping to put mine on this weekend long as i can find a dual pass by then!
Old 10-16-2012, 11:39 AM
  #154
Hockeyman's Avatar
You won't regret it! I did dual pass and the phenolic spacer at the same time about 6 months ago. Runs like a champ.
Old 11-06-2012, 02:10 AM
  #155
chowell_09's Avatar
So the hardware ZZP supplies includes 3 spacers, longer bolts that go around the perimeter AND 2 longer head studs?
Should I just buy the hardware from ZZP or just get the bolts from lowes. I bought the spacer used.... no bolts
Also, the stage 2 belt fits fine with the spacer or will I need to put back the stock one? Im on a 2.8 pulley
Old 11-06-2012, 07:51 AM
  #156
TStone's Avatar
Both belts will work fine, but I'd go with stoxk
And no, it does NOT come with head studs. It comes with all the bolts you need to bolt the manifold TO THE head. & the infamous elusive 8th bolt
I'd just order the hardware from zzp. That way you know they're all the perfect link.. & we all know zzp is the **** sooooo
Old 11-06-2012, 08:55 AM
  #157
mrbelvedere's Avatar
spacer not worth it
Old 11-06-2012, 08:57 AM
  #158
Tjolley's Avatar
i second this^^^
  #159
i'd say its worth it!
i installed this and the dual pass last weekend.
i can go romping around town for a while, pull over and pop the hood
the engine block = hot
the intake manifold and s/c = cool to the touch
i can't tell what my temps actually are though because my interceptor magically stopped working the day i installed these parts
Old 11-06-2012, 08:59 AM
  #160
Tjolley's Avatar
i will be leaving it off my next build...
Old 11-06-2012, 09:04 AM
  #161
Tjolley's Avatar
if u want to make a huge difference put meth or a 50 shot of nos on it...
i did the nos wen i was factory gms2...worked well all day long...a 10lb bottle lasted me months..
Old 11-06-2012, 10:47 AM
  #162
ebristol's Avatar
Spacer is worth it.
Old 11-06-2012, 10:51 AM
  #163
Vander Nars's Avatar
Originally Posted by mrbelvedere
spacer not worth it
iv heard nothing but good things about the spacer, care to explain that with a lil more detail.
Old 11-06-2012, 10:54 AM
  #164
ebristol's Avatar
It stop heat transfer.
Old 11-06-2012, 10:56 AM
  #165
people that put it on said they saw a 10 deg drop at cruise on iat2 i dident see jack even with a new ic pump
Old 11-06-2012, 10:58 AM
  #166
phenolic will stop direct heat transfer but it wont stop radiant heat transfer which is what will still put the im back up to what it was without a spacer
Old 11-06-2012, 11:04 AM
  #167
chowell_09's Avatar
Thanks for the info TStone and Rice.
as far as it not being worth it....I already have it and its a simple install so I'll give it a shot and see whats up.
Like Vander said, I have read nothing but good things about it. It can't be that bad.
  #168
BlackBriar's Avatar
Subd
Old 11-06-2012, 11:07 AM
  #169
its the placebo effect lol it may slow down the temp transfer some but unless you can completly isolate manifold from heat it is pointless
Old 11-06-2012, 12:38 PM
  #170
Got Bewst?
Bluelightning's Avatar
The biggest thing I noticed with it was when i'm stopped at a light my IAT2's will climb very very slowly compared to without it. I liked that for when I go to the track.
Old 11-06-2012, 12:48 PM
  #171
ebristol's Avatar
That is also part of the problem. The engine bay is hot.
You also need one of these!
Old 11-06-2012, 12:58 PM
  #172
Administrator
Administrator
Staged07SS's Avatar
Well, what do we have here???
Old 11-06-2012, 01:07 PM
  #173
Tjolley's Avatar
anyone ever think that the bearings in the sc get hotter than the engine temp...from wat ive read they can get over 300 degrees..
Old 11-06-2012, 02:35 PM
  #174
something else to hold in the manifold
Old 11-12-2012, 08:32 AM
  #175
31 degrees out, while moving. this good?
Quick Reply: A must have for EVERY LSJ
