A must have for EVERY LSJ
Old 11-12-2012, 08:36 AM
  #176
turbosmart4's Avatar
^no bro. U are having internal coolant leak somewhere.......
Jk
Old 11-12-2012, 11:16 AM
  #177
YelCal7's Avatar
Originally Posted by ebristol
That is also part of the problem. The engine bay is hot.
You also need one of these!
Where did U get these!?
Old 11-12-2012, 11:53 AM
  #178
Hockeyman's Avatar
31 degrees out, while moving. this good?
I'd say no. Mine are less than 10* apart while cruising.
Old 11-12-2012, 11:55 AM
  #179
looking at other peoples results i'm thinking the same thing... whats my deal then lol? i wasn't even running hard htis morning, i was simply cruising to work.
ottp stg1 heat exchanger
dual pass
phelonic spacer
2.8"
problemos?
oh and mrbelevire wtf is that thing? TELL US!
Old 11-12-2012, 01:02 PM
  #180
mrbelvedere's Avatar
it was a heat shield that jbp did that was useless
Old 11-12-2012, 01:07 PM
  #181
Hockeyman's Avatar
dual pass
phelonic spacer
2.8"
problemos?
Air stuck in the system somewhere?
Old 11-12-2012, 01:18 PM
  #182
must be. option b needed i take it, or is there a way to purge the system better? we refilled it when installing the spacer and dualpass
and this ones ever worse, just caught it on my lunch break! thats 40 degrees higher! iat1's still ambient and should be since i got an injen lol
Old 11-12-2012, 01:19 PM
  #183
oh. that seems like a useless place to put a heatshield lol
Old 11-12-2012, 01:27 PM
  #184
Hockeyman's Avatar
Try to take off the top screw on the stock h/e. FYI fluid will probably start gushing out, but just re-cap it when this happens. Should get all the air out.
Old 11-12-2012, 01:33 PM
  #185
while its running i take it? sorry i need things spelled out for me usually, i'm an enthusiast first and a mechanic second lol, havent dealt much with cooling systems short of this car yet
thank you for the help!
and i know everythings working good when i see fluid going through the i.c. filling deal steady!
Old 11-12-2012, 01:36 PM
  #186
RooTBeeR's Avatar
you can never get all the air out of the stock system with that POS filler neck, opt.b or flow through with a bleeder line out of the top of the H/E are basically the only ways to be sure its all out.
when you do it, make sure you follow the gm(CED) option b directions for hose routing. it does make a difference.
Old 11-12-2012, 01:43 PM
  #187
you mean to do this, IF i wind up doing an option b, or if i just attach and run a piece of hose out of the top of the h/e?
and if i do attach a hose to the he, how do i ensure i don't lose all my coolant?
Old 11-12-2012, 01:48 PM
  #188
RooTBeeR's Avatar
https://www.cobaltss.net/forums/6711153-post11.html
http://www.crateenginedepot.com/Opti...TB-P10552.aspx
http://www.crateenginedepot.com/pdfs/sidekit.pdf
Old 11-12-2012, 01:55 PM
  #189
option b is the best bang for the buck
Old 11-12-2012, 02:03 PM
  #190
so in the end the line coming from the top of the surge tank goes to the top of the stock heat exchanger? and i'd need to drill a hole and put a fitting for that
Old 11-12-2012, 02:07 PM
  #191
Hockeyman's Avatar
Like i said earleir about bleeding it, there is a screw on the top of the stock h/e. This is the place to run the option B line, or you can temporarily bleed the air out by taking it out while the car is running.
Old 11-12-2012, 02:15 PM
  #192
OH ok thanks everyone! gonna give it a shot after work and see how she does after that.
Old 11-13-2012, 07:10 AM
  #193
Administrator
Administrator
Staged07SS's Avatar
This.
and this.
People are finally learning this....
Old 11-13-2012, 08:30 AM
  #194
cavfiredesire's Avatar
Unless you only have the zzp intercooler...then your screwed lol.
Old 11-13-2012, 09:03 AM
  #195
lol ive known since before its release but others are still clueless
Old 11-13-2012, 03:28 PM
  #196
the trick to that elsuive IM bolt
Old 11-13-2012, 09:29 PM
  #197
RooTBeeR's Avatar
lol, says the video is private?
Old 11-14-2012, 01:51 AM
  #198
sLAsh's Avatar
This is how the bolt remains elusive. Covering it's tracks behind itself at every opportunity.
Old 11-14-2012, 02:38 AM
  #199
FryLoch's Avatar
So I installed my phenolic a couple weeks ago and it made absolutely no difference in iats.
Old 11-14-2012, 09:12 AM
  #200
Tjolley's Avatar
bingo....
Quick Reply: A must have for EVERY LSJ
