My full rich problem is back!!!!
Old 03-15-2013, 08:23 AM
Vander Nars's Avatar
went out to log today everything was running perfect and then it pegged out 10.0 again im about ready to crash this mother ****** into a wall and just get another car.
Recap on what iv done so far.
I have no cels when this happens
cleaned maf and map sensors.
changed spark plugs to copper type.
James said may be a faulty upstream o2 sensor so im install this new one I have today but I always thought faulty o2 sensor throw cels.
Old 03-15-2013, 08:41 AM
Tjolley's Avatar
Force the car into open loop for a day and see if it dose it.
Old 03-15-2013, 08:44 AM
Tjolley's Avatar
Is the car going rich during Wot?
Also run the car with only speed density only then try MAF only.
I wonder if u have something out of wack there..
Old 03-15-2013, 08:48 AM
ok i just looked into my logs and iv got a pic of my car doing a 2nd gear pull when its running normal and when its pegged rich ill post them and tell me what ya think.
update- uploading now.
Old 03-15-2013, 08:57 AM
2nd gear normal pull afr of 11.0
2nd gear pull pegged rich 10.0 afr
Old 03-15-2013, 09:05 AM
Something is happening in the airflow that causes it to jump from 8.77 to 41.00 and that causes my injectors to pump out more fuel from 65% to 86% does this help explain what is broke? lol
Old 03-15-2013, 09:10 AM
Tjolley's Avatar
Well on the first pic ur car isn't at operating temp. 140*
The second one it is..there could be somethin there.
Old 03-15-2013, 09:12 AM
Tjolley's Avatar
Put the car in speed density and see wat happends..
Wonder wat ur commanded afr is also
09BlueBaltSS's Avatar
First pic cold motor? Also how can u be at 32psi and only flow 8 lb/min?
Old 03-15-2013, 09:21 AM
user 72239's Avatar
I hope hes not at 32 psi or that is one spun M62 lol
Old 03-15-2013, 09:25 AM
my car is not at 32 psi that is the airflow people lol. the car being only 140 does not effect the 8.77 ill post a pic of 3rd gear pull that is the same way.
Old 03-15-2013, 09:27 AM
11.0 is what my afr is when its not ******* up and what is speed density and how to i put my car in it?
Old 03-15-2013, 09:29 AM
ULWizSS's Avatar
Bad 02 sensor
Old 03-15-2013, 09:30 AM
Tjolley's Avatar
You have to subtract barometric air pressure.
Old 03-15-2013, 09:31 AM
i hope hes not at 32 psi or that is one spun m62 lol
17.3?
Old 03-15-2013, 09:33 AM
Had a derp moment. Also thought he was Turbo swapped so 32 psi and 41 lb/min kinda lined up in my head lol.
Ok carry on haha.
this is a 3rd gear pull at running temps with a 8.91 ve airflow and 67 injector duty
Old 03-15-2013, 09:35 AM
Originally Posted by ULWizSS
Bad 02 sensor
upstream sensor? i have no code but im guessing that could be it lol
Old 03-15-2013, 09:50 AM
Administrator
Administrator
Staged07SS's Avatar
Ok carry on haha.
He's flowing 33.86 lbs/min (MAF)....
Sounds like a bad O2 sensor to me as well.
Old 03-15-2013, 09:52 AM
well im replace the o2 sensor today, do yall think that is whats causing the ve airflow(red one) to spike from 8-9 to 41 and making me dump fuel?
Old 03-15-2013, 09:53 AM
Administrator
Administrator
Staged07SS's Avatar
Yes. What did the old sensor look like when you pulled it?
Old 03-15-2013, 09:54 AM
Omnigear's Avatar
Old 03-15-2013, 09:56 AM
never pulled it yet iv got to get the tools after lunch.
Old 03-15-2013, 09:57 AM
Administrator
Administrator
Staged07SS's Avatar
Ok.... Sounds good.
Post up your findings when you get to it.
Old 03-15-2013, 10:34 AM
1AJeremyD's Avatar
Could be a slow sensor. Happened on a couple of cars I've looked at. I would replace it and report back.
Quick Reply: My full rich problem is back!!!!
