is my set will be safe?
i have a 06 SC, my mod are cold air intake , GM stage 2. header down pipe and cat back . i want to change my stage 2 pulley (3.1 ) drop to 2.9.
my question is 2.9 pulley will be safe with stage 2 injectors?
usually the stage 2 injectorsare good down to a 2.9, anything smaller you wanna go 60's but you should def have a wideband, and if you can an interceptor
the interceptor will let you see the duty cycle of the injectors and see if you are exceeding it, the stage two injectors can flow more than 42 lbs/hr what happens is the fuel pump compensates for the limited flow of the injectors by forcing more pressure into the fuel rail intern forcing more fuel through the injectors. The injectors can only take this excessive flow for so long before biting it
if i get a 60s from ott , do u guys know how much they charge for the tune?
DANRICKARD
10-01-2015 12:08 AM
