My stock psi is 13(not that im complaining)
Hey not that im complainin, but when i rev the engine the boost gauge goes to 15 right in the line, when when i floor it and im moving so i get that little bit of resistance it hits the line between 10 and 15 which should be 12 or 13 ish. Just wondered if anyone else had the same thing. It got better as the engine broke in. Cause when i got it, it would only hit 9 when i floor it. I dont know, its running fine so im not complainin...
The amount of boost you're going to get is dependant on alot of things, one of those being the temperature of the air. Hotter air = less dense = more "boost" you're going to find in the winter you get less PSI of boost because the air coming in is alot colder, hence more dense.
I wouldn't worry about how much boost you get when you're reving and not moving, if you're hitting 12.5ish when you step on it and the car is moving, then all is well.
I've actually never sat in my car reving it without being in motion to see if the boost gauge moves...I'll check after work to see what happens.
Theoretically if the engine isn't under any stress there's no reason to be going into boost
Originally Posted by ggarcia86
i used to do it to see if we had some sort of wastegate or blow off type sound cause that'd be nice
Everyone and there slow uncle has a blow off valve, S/C whine rules all!
