Narrow Band vs Wideband
Old 06-16-2007 | 11:20 PM
Hopeless Regret's Avatar
I want to get an air/fuel gauge for my 06 SS/SC but I had a couple questions first. If I just bought the gauge and wired it into my stock o2 sensor would I get an accurate reading as if I got the AEM wideband system which comes with a new o2 sensor? Whats the difference between the sensor AEM gives you and the one thats on my car? What seems to be the most popular gauge everyone else is getting?
Old 06-16-2007 | 11:26 PM
NJHK's Avatar
No, you wouldn't get a accurate reading. It all revolves around your narrowband sensor...which is in it's name...narrow with reading. Narrowband sensors were designed to help your stock computer revolve around 14.7 a/f but it can not tell you accurately how lean or how rich you are.
Get a actual wideband unit. Getting the gauge will just waste your time and mislead you.
When you have a issue and someone asks you what your a/f ratio is, are you going to say "It's a little bit on the lean part"?
Old 06-16-2007 | 11:31 PM
Mikey851's Avatar
No, a wideband 02 sensor is much more accurate. It has to do with how the ECU controls AFR. A narrowband 02 is looking for a thing called "cross counts" in which the ECU switch over a small amount from rich to lean because the catalytic converter needs both conditions (only slight changes) to function at the best of it's ability. The narrowband is good at quickly reading this slight change and relaying it to the ECU by changes in voltage due to oxygen changes.
A wideband 02 does not constantly switch and views the "big picture" as far as the AFR goes. This allows a much more accurate reading of the true AFR. In other words, no, a narrowband will not produce an accurate reading.
Edit: You got to it before me NJHK haha.
Old 06-16-2007 | 11:35 PM
Witt's Avatar
The sensor in your car is used by the car's computer to measure if the amount of fuel per unit of air is correct while doing nearly anything other than wide open throttle. This sensor is commonly referred to as a narrowband oxygen sensor in that it reports back a 0-1v signal that has virtually no resolution at anything other than 14.7-1 a/f. This is a tool used by the car's computer to insure the car produces the lowest emissions possible.
The wideband or UEGO (Universal Exhaust Gas Oxygen) sensor that your AEM controller comes with reports back a 0-5v signal and has resolution from around 10-1 all the way to nearly 18-1. This is a tuning tool unlike the narrowband as it provides you with feedback at all throttle conditions most importantly WOT where the greatest amount of heat and power is made.
Old 06-16-2007 | 11:37 PM
NJHK's Avatar
Yeah...that's what I what I meant.
******* Biter lol
Old 06-16-2007 | 11:49 PM
CTCOBALTSSS's Avatar
Narrow Band equals not accurate which equals waste of money.
Old 06-17-2007 | 12:08 AM
Mikey851's Avatar
******* Biter lol
Haha, I was getting at the same thing as well.
Old 06-17-2007 | 12:10 AM
DoubleClutchin_ION2's Avatar
narrow = light show
wideband is the way to go
Old 06-17-2007 | 12:16 AM
Mikey851's Avatar
Originally Posted by Cobalt_SDN
narrow = light show
Nice! You're exactly right, on a UEGO the LED would appear to be on meth lol
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
n20saturn
09-30-2015 12:26 AM
z28addiction
09-28-2015 12:03 AM
dennis69
09-22-2015 08:56 AM
Quick Reply: Narrow Band vs Wideband
