need help.
Old 01-19-2010, 09:26 PM
utsadude's Avatar
Originally Posted by rico
yeh same here idk . im thinking ecu prolly fried?
More likely than the tune going bad...
rico's Avatar
neh i flashed like other 4 tunes that worked fine with no probs for days and nada......
Old 01-19-2010, 09:28 PM
hatrickstu's Avatar
revert back to an older tune and see what happens
Old 01-19-2010, 09:29 PM
rico's Avatar
did so. like 4 of them lol.
Old 01-19-2010, 09:30 PM
hatrickstu's Avatar
i really dont know man, can you get your hands on a buddies ecm of the same year you already have unlocked?
Old 01-19-2010, 09:32 PM
rico's Avatar
idk. i dont think anyone has 07 lol most are 06. yeah **** my luck right?
Old 01-19-2010, 09:45 PM
HIValicious's Avatar
Bummer man! I'm HPtooned & I have an '07, but I'm in NY. Hope you figure it out. No one likes to hear about a Cobalt that doesn't start.
Old 01-19-2010, 09:46 PM
rico's Avatar
yeh i guess ill try to get an ecu
Old 01-19-2010, 09:47 PM
sundevil07's Avatar
hmm yeah sounds like you might have a fried ecm
utsadude's Avatar
Anything Ben can do?
Old 01-19-2010, 09:49 PM
  #36
rico's Avatar
idk not much he can do that i can think of lol
Old 01-19-2010, 09:50 PM
  #37
utsadude's Avatar
Idk. Just throwing out ideas.
Old 01-19-2010, 09:52 PM
  #38
rico's Avatar
yeh I know lol . ima see if he can find a spare one at the dealer or sumthing idk
Old 01-19-2010, 09:58 PM
  #39
sstaton1983's Avatar
i cant believe no one knows its the theft system. if you turn the key over and the engine dont crank,more than likely its in your key or pass lock sensor.is your security light flashing? and also if you jump across the starter it will start and die because the pcm thinks the car is being tampered with and cuts off fuel and spark.
Old 01-19-2010, 09:59 PM
  #40
qwikredline's Avatar
If you think about it the clue is that you can jump it and it runs. check the main power cables from the starter to the postive post of the fuse box. If that bolt is loose at all you will get exactly what you describe. The other thing that can bite you are grounds again a big ground next to the starter under the oil pressure switch and oil cooler... tite tite tite
Old 01-19-2010, 10:03 PM
  #41
checked all that. when i put key on fans go right now. NEVER HAD HAPPENED BEFORE. for you hptuner users yall know when u start uploading a tune while its doing it it dispays on the gauge LOW FUEL, POWER STEERING ETC.. well as soon as i turn the key with no hptuners or anything pluged it keeps doing that and that its not suppose to happen so idk. mayb etc took a ****?
i didnt see this part, whoops your pcm is on the fritz, try un plugging it for a minuet, plug it back in and reprogram. you probly got it all locked up with all the constant flashing.
Old 01-19-2010, 10:04 PM
  #42
rico's Avatar
no theft light on or anything.
Old 01-19-2010, 10:08 PM
  #43
i thought he said it starts and dies, if thats the case that is what it is designed to do when you bypass the ignition switch.
if no theft light, or security dtc set in pcm and bcm, than your going to need a pcm
  #44
rico's Avatar
yah starts and dies. but no theft light off or anything so i think its the ecu. because its keeps saying low fuel. power steering the same way it does when ur uploading a tune but im not..
Old 01-19-2010, 10:14 PM
  #45
i am a gm tech and the first rule when programming is put a batt. charger on it. i have fried pcm.s in the past due to low voltage while programming, you should keep batt voltage around 12.6. maybe this happend to you? maybe not?
Old 01-19-2010, 10:15 PM
  #46
rico's Avatar
i thinks thats what happened. cuz i took the batt to get checked and all and it needed charging. and before this all happened i was uploading a tune so i think thats what happened
Old 01-19-2010, 10:18 PM
  #47
Originally Posted by sstaton1983
i am a gm tech and the first rule when programming is put a batt. Charger on it. I have fried pcm.s in the past due to low voltage while programming, you should keep batt voltage around 12.6. Maybe this happend to you? Maybe not?
qft........
  #48
at least its easy to change, i like those i charge 1.0 to replace and .5 to program customer pay of course LOL
Old 01-19-2010, 10:19 PM
  #49
rico's Avatar
are 07 and 06 ecus compatible or no? let me know since i need to find one now lol
Old 01-19-2010, 10:22 PM
  #50
as far as i know, however they are vin specific. but with hp tuners i guess you can get around it, i am not familier with hp tuners.if you by a new one the 06 and 07 should be identical
Quick Reply: need help.
