need help.
#39
i cant believe no one knows its the theft system. if you turn the key over and the engine dont crank,more than likely its in your key or pass lock sensor.is your security light flashing? and also if you jump across the starter it will start and die because the pcm thinks the car is being tampered with and cuts off fuel and spark.
#40
If you think about it the clue is that you can jump it and it runs. check the main power cables from the starter to the postive post of the fuse box. If that bolt is loose at all you will get exactly what you describe. The other thing that can bite you are grounds again a big ground next to the starter under the oil pressure switch and oil cooler... tite tite tite
#41
checked all that. when i put key on fans go right now. NEVER HAD HAPPENED BEFORE. for you hptuner users yall know when u start uploading a tune while its doing it it dispays on the gauge LOW FUEL, POWER STEERING ETC.. well as soon as i turn the key with no hptuners or anything pluged it keeps doing that and that its not suppose to happen so idk. mayb etc took a ****?
#43
if no theft light, or security dtc set in pcm and bcm, than your going to need a pcm
#44
yah starts and dies. but no theft light off or anything so i think its the ecu. because its keeps saying low fuel. power steering the same way it does when ur uploading a tune but im not..
#45
i am a gm tech and the first rule when programming is put a batt. charger on it. i have fried pcm.s in the past due to low voltage while programming, you should keep batt voltage around 12.6. maybe this happend to you? maybe not?
#46
i thinks thats what happened. cuz i took the batt to get checked and all and it needed charging. and before this all happened i was uploading a tune so i think thats what happened
#47
as far as i know, however they are vin specific. but with hp tuners i guess you can get around it, i am not familier with hp tuners.if you by a new one the 06 and 07 should be identical
