Need help (oil pan removal)
As the car sits now 85% of the coating came of my s/c blades and has clogged the engine . I took off the top cover cleaned it out. Now I am trying to get the damn oil pan off but not having much luck .I think(lol) I got all the bolts off but THE DAMN THING WILL NOT BUDGE! If Anyone had it off and can throw some pointers my way it would be great.
i went and bought a pry bar...and it worked like a charm....good luck ...that high temp rtv is no joke....lol
i belive there is 14 bolts that hold it on
bur an ss so im not sure...if its the same bolt pattern
ran nitrious a few times back in december now its more for show . I am sure thats not what caused this.(had it apart since) I heard the belt squeal but it was very quick got about 1/4 mile from home and the s/c siezed up. took off the belt so I could drive home and thats when I saw the first piece inside the s/c thats the bigger piece in the pic. I turned it backwards freeded it up ran great (also put in new blade rotors ,s/c oil an repacked bearings) then started to get a knock but it was speratic. took off the cover and it was not getting much oil to the top . so I have taken apart as much as I can or know how and am just depending on luck that everthing else is ok.If not well for sale 1 cobalt ss s/c haha never It will be fixed and ran the **** out of some more 73,823 miles track raced since 24,000 2.7 pulley since 35,000 7800 rpm limiter since 39,000 surprised it lasted this long.I did a compression check before I started teardown 198-202 so still good there and leakdown was about the same a last dec
1 more thing over 73,000 miles oil changed every 3,000 miles or less and 0 sludge in the oil pan mobil 1 is the **** lol
importkiller
09-30-2015 08:18 PM
