need help take off the pully!!!
2.stick a 15mm where the tensinor arm is and push forward
3.belt should have slack now and pull it off the supercharger pull
4.take 4 bolts off the supercharger pulley,and remove pulley..
If you're removing the stock press-on pulley, here's the tool I make that makes the job much easier. It's available at http://www.smoothflowpulleys.com/Pulley_Puller.html It pulls off the stock pulley, then the threaded shaft, nut, and washers are used to press the new pulley hub on. It's available for purchase or rental but the rental option isn't up on the website yet.
Nate
Nate
Blue04RedLine
01-10-2006 11:37 AM
