need info on dual pass water pump
what exactly does the dual pass water pump do for your car, how do you install it if there is a link already then send it to me please
Thanks
Thanks
It improves cooling by making your water pump use two cycles instead of one. Install is a little tricky, you have to drain the coolant and oil and drop the engine to get to the bottom end of the block. Try searching for more info.
