need some advanced help
Old 04-24-2009 | 05:15 PM
coopn8r's Avatar
Edited w/<3
Old 04-24-2009 | 05:29 PM
KillinKrullin's Avatar
and for the record im 5'8" 165lbs of pure man meat! bitch
Edit: Maybe i should put lawls (lol's) on the end of my jokes?
Old 04-24-2009 | 05:31 PM
coopn8r's Avatar
For the Record.. I am 6'0" tall and 155lbs of pure muscle
Btw: I'm bring the boxing gloves to the meet.. It'll be good times Not the MMA style, but big ones.. No broken noses hopefully.
Old 04-24-2009 | 05:43 PM
-Jayson-'s Avatar
/ END Thread Jack
please try to stay on topic and thanks for the help so far.
Old 04-24-2009 | 05:46 PM
i hate those big dumb gloves, i go bareknuckles.
/end jack
Old 04-24-2009 | 05:47 PM
Kennyspec's Avatar
do a leak down test.....bring the cyl to TDC of compression stroke and listen to where the air is escaping from, intake valves, exhaust valves, piston rings.....
Old 04-28-2009 | 08:28 PM
Tennpenn83's Avatar
this ever get resolved?
Old 04-28-2009 | 10:05 PM
StevesBlack06's Avatar
X2?????
u can reuse the cam cap bolts, i also reused my cam gear bolts, i kno they are torque to yield but i just loctited em. as for timing being off its unlikely with a holding tool if it was used properly. im guessing you werent at TDC and you also gotta make sure that all of your valves are closed while at TDC before you reinstall. it is a bitch to retime it without taking off the front cover. i had to set my gears, find the colored links and count the links between the colored ones. then line up the notches on the gears that many links apart from one another. should be 10 and 2 at tdc number 1 and 4 compression stroke. if this made sense then sweet if it didnt then sorry...
Old 04-29-2009 | 12:59 AM
damien's Avatar
Timing this motor is cake. Hell, even building it is.
Old 05-12-2009 | 09:36 AM
spooler's Avatar
yah, whats the status on this one?
turbochargedss2012
09-20-2023 01:17 PM
jmelton327
09-25-2015 10:44 AM
Cptnslo
09-24-2015 10:32 AM
TylerJHowell
09-21-2015 07:47 PM
TheSandMan
09-20-2015 07:02 AM
