Need some help with installing smaller pulley and other supporting mods!
Im helping a friend out come soon after x-mas when he has enough to buy what he needs left.
Hes wanting to install a 2.8 pulley, 60lb injectors, dual pass heat exchanger, option b, stage 2 belt, and a adjustable tensioner. Is there a really detailed how to on how to do all these mods? If not would someone be willing to walk me through on this thread on what the process would be?
He still has the stock pulley currently installed.
well if you wanna drop pulley sizes your gonna have to look into a new hub for the s/c. the stock pulley is pressed on and aftermarket pulleys dont use the factory hub. i reccomend the ZZP modular pulley system. its sick and not too expensive. everything you listed can be found in the "how to" section of this site. there are a lot of good write ups and how tos. just use the search feature on the site here and it should pull up anything you could want. good luck with your install
