needdd answer asap????
hey guys i have a 07 cobalt ss/sc n i had the gm stage 2 (injectors,stage tune,pulley) n i was gonna sell it to my friend which has a stock ss, can i just take off the injectors n my ecu n put it on his car n i put his stock injectors on mines n his computer?????? if not what do i have too do
I'm pretty sure if you switch your ECM, injectors, pulley, to his car, and put his ECM, injectors, and pulley on your car. You will be back to stock, and he will be stage II. The only problem I for see is the vin code. I know once your ECM is flashed its a stage II registered vin.
But the deal is this...(edit) the vins need to be changed. He has a stock ss/sc I'd assume not a stock 2.4...
09BlkCrusader
09-09-2015 04:47 PM
