new gmpp clutch, break in period??
Old 04-27-2012, 01:10 PM
574
574's Avatar
I have, but still trying to go slow over big bumps and speed bumps still sucks.... gotta throw it in neutral so you dont feel like your riding a bucking bronco
Old 04-27-2012, 02:16 PM
yes well i got the pedal covers for two reasons
they look awesome
and yes gas pedals twice as stiff. now, i was used to the touchyness of the old pedal but this one just feels more legit.
link to said part
Pedal Cover Set for Manuals 12499876
Old 04-27-2012, 02:18 PM
after installing mine i had trouble for a few weeks getting mine into gear at higher rpms when going to switch gears quickly. dunno if it was me getting used to it or what but its on my list of best mods done to car. youll enjoy it!
did my catback purchase from you fund this? lol
once it settles in forsure its one of the best mods! same with the pedals and STS! holy ****, its a different driving machine now!
and actually that moneys going to a zzp longtube header!
I couldn't swallow paying someone $600 to change my clutch. I honestly couldn't believe how easy it was after doing it. Took me 8 hours to swap. That was including building an engine cradle to hold the motor while the trans was out haha. I could swap it in half the time next time around.
idk man im too prone to losing bolts and ****
Old 04-27-2012, 04:14 PM
SaberD's Avatar
dont smoke trees when you are working on your car. problem fixed. rofl.
on a more serious note, when doing a long job, i always put the nuts and bolts in labled ziploc bags, and i also label all electrical connectors and hoses with masking tape using letters and numbers. taking pictures helps too. I also always make sure my garage is clean, and that I have specific spots for each tool. It's also important to put your tools back when you are done using them. its easier to get them out of the toolbox when you know where they are than to look around for 15 minutes because you forgot where you put it lol.
Old 04-27-2012, 09:13 PM
Got Bewst?
Bluelightning's Avatar
Lol ya I know it can seem overwhelming. It was for me when I first looked at it. But I just took my time and followed the LSJ build book and it was really easy. But I know some poeple aren't as mechaniclly inclined as others. The money I saved installing the clutch myself I put towards my TVS haha.
Old 05-01-2012, 10:37 AM
haha i read that trick in the buildbook!
well i've gone 350 miles so far, cars running great and shifting like a dream. bout time to start trying some launching! and burn some rubber!
Old 05-01-2012, 02:49 PM
insylem's Avatar
Thinking about getting the GMP clutch as well. Mine does the not let it out of gear crap at high RPMS, tried changing my clutch fluid (It was black with blackk floating stuff in it) That didnt work. I dont really have the facalities to change the clutch myself. I read the LSJ Power book (Its a great book) I dont have the means to drop my transmition or engine frame assembly like it says in the book, so looks like I'll have to have a shop do it. I'm sure Rick would be glad for the money / buisness though. I've been to his shop a few times for stuff. He seesm to have a good operation and crew going.
Old 05-01-2012, 02:56 PM
nizzle's Avatar
Did 500 miles on mine. Did not give it over 50% throttle, and did not hold a specific rpm for a sustained period of time. Worked FLAWLESS.
Old 05-01-2012, 03:06 PM
yea... i wound up flooring it and going about 145 the other night with my buddy feil. but still, works flawless
Old 05-01-2012, 03:16 PM
Got Bewst?
I put my TVS on Friday and went for a quick rip. First time I banged through the gears since I put the clutch in and I found myself blowing shifts like crazy like a noob lol. Guess I gotta learn with this clutch. Anyone else find this?
Old 05-01-2012, 04:37 PM
  #36
i've missed 2nd once so far but thats probly cuz of the sts settling in
Old 05-02-2012, 07:44 AM
  #37
zfissette's Avatar
if there is a set that includes the whole gas pedal assembly then im totally down. i have a feeling mine is starting to develop a bad spot right near the start of its travel.
Old 01-08-2013, 09:48 AM
  #38
briank6102's Avatar
Hey guys, I just put a gmpp upgraded clutch and tob w/ clutch pipe and new flywheel bolts and clutch plate bolts in 2 days ago. I've put 64 miles on it so far. Sometimes just normal driving it is hard to shift into gears And also the engagement point is basically on the floor.. i Find sometimes if i mash my Pedal to the floor it shifts Easy into gears like normal. I'm not sure if it needs bleeding or if its just part of breaking in the clutch (I've never done a clutch swap until now or even drove a car with a upgraded clutch in it lol).. 😔 I have a 07 ss/sc w/ 2.6, 60's, meth, 3" dp, stage 2 belt w/ ot tensioner, dual pass plate, phenolic spacer, hurst sts, & WickedSS tuned! 👍 If anyone could chime in and help me out before I have to do worn not needed!
Old 01-08-2013, 09:52 AM
  #39
The grab point for the gmpp is pretty much on the floor that didn't change for me.
as for sometimes hard shifting, check your shift linkage cable in front of your shifter.... make sure thats prperly adjusted. doesn't take much to make shifting harder than it needs to be
Old 01-08-2013, 09:58 AM
  #40
briank6102's Avatar
I haven't messed with the shifter linkage cause it was perfect before I did the clutch swap (from stock) for 5k miles.. Do you think that could still need re-adjusting? I could see that changing if the tranny was changed but not a clutch.. How many miles have you put on your new clutch? You love it or what? And downsides to the clutch?
Old 01-08-2013, 12:48 PM
  #41
Powell Race Parts's Avatar
bleed it again there is air in there. good luck
Old 01-08-2013, 12:55 PM
  #42
briank6102's Avatar
I used a mighty vac to bleed it.. And still hard to engage.. I'm going to check shifter linkage now..
Old 01-08-2013, 01:00 PM
  #43
briank6102's Avatar
Thumbs up
Thanks guys for the help!! 😄 Shifter linkage was the cause! I guess it just was off just enough to still drive but to not engage smoothly!!
Old 01-08-2013, 01:01 PM
  #44
06G85's Avatar
The GMPP upgrade for the LSJ does not need a break in period. ( I know, I have it)
Old 01-08-2013, 01:05 PM
  #45
574
574's Avatar
You serious?
Old 01-08-2013, 01:34 PM
  #46
briank6102's Avatar
The build book says that there's a couple heat cycle break in.. It doesn't say a 500 mile break in from what I've seen but it does say don't go ripping through gears as soon as you get done installing..
Old 01-08-2013, 01:36 PM
  #47
couple of normal starts its done. pedal then comes up a bit; assuming properly installed, sealed and bled.
  #48
briank6102's Avatar
Driving your car with that new clutch should be done with care for the first few heat cycles—
so don’t plan on drag racing in the first 10 minutes out. Once you have a few easy engagements
in the clutch and at least one heat cycle, the clutch should be ready for regular usage—
if there is such a thing with one of these rockets!
Old 01-08-2013, 02:06 PM
  #49
insylem's Avatar
Here's the quote from the build book:
its a bit cheesy but gets the point across.
The build book is covering the OEM LSJ Clutch though...
Old 01-08-2013, 02:12 PM
  #50
is that quoted from the gm build book?
Quick Reply: new gmpp clutch, break in period??
