New IC Pump NEED HELP!
Old 03-14-2012, 07:12 AM
sjc0013 Licks windows
reduf99's Avatar
But its also a bigger engine though what's the 6.25 compared to a 4 cylinder
Old 03-14-2012, 07:26 AM
Sweet CobaltSS's Avatar
True, but generally more flow is NEVER a problem. Our factory pump was 8 GPM.
Old 03-14-2012, 07:28 AM
Administrator
Administrator
Staged07SS's Avatar
I can guarentee that you still have trapped air.....
w/o Opt. B it is very hard to get the system to purge all the air. I just installed the GMR dual pass, and a new pump while I was at it. My Opt. B tank bled all of the trapped air almost immediately. Un-bolt the fill bracket from the blower (if you still have one), and lift it up a bit. This will help burp some of the air pockets out of the coolant.
Old 03-14-2012, 08:09 AM
reduf99's Avatar
Ill have to give it a try(I'm no mechanic in anyway) when I get done work.
Old 03-14-2012, 08:11 AM
Administrator
Administrator
Staged07SS's Avatar
It's ok man.... we all start somewhere.
By the way.... where in PA are u located??
Old 03-14-2012, 08:23 AM
reduf99's Avatar
Right on the outskirts of quakertown and pottstown
Old 03-15-2012, 07:15 AM
Administrator
Administrator
Staged07SS's Avatar
Oh...ok...jw.
I've seen a car around my area that looks very similar to yours. Thought I would see if it was you. I'm a little north of scranton.
Old 03-15-2012, 07:37 AM
reduf99's Avatar
Yea there's like 5 ss's around here atleast that I know of so getting help for this car is kinda hard
Old 03-15-2012, 08:59 PM
395 plus's Avatar
I have zzp stage 3 he, dual pass, option B, 2.8 pulley, zzp IC pump and at cruise I run about 20-30 degrees over the ambient air temp year round. When I installed it all it still took a bit of driving to purge all the air but the option b does a nice job.
Old 03-16-2012, 12:21 AM
nizzle's Avatar
Thats whats css.net is here for
Old 03-16-2012, 12:35 PM
  #36
383_Stroker's Avatar
If your IAT2s are 20-30 degrees over your IAT1s.. you're not in too terrible of shape.
Old 03-16-2012, 12:41 PM
  #37
reduf99's Avatar
Yea it took a few days but now I running like 84-95 will driving so its all good I guess I just had some air bubbles in it but thanks for all the help guys
Old 03-16-2012, 12:46 PM
  #38
Administrator
Administrator
Staged07SS's Avatar
This.....
It's very hard to determine what IAT2's actually are, because they can vary soo much. Things like throttle position, daily temp, modifications, etc. can alter them. I always say my IAT2's are around 15*F above IAT1 on average. On average meaning sometimes they dip below 15*, and some times they are over 15*. The best way to test them is to take a nice steady cruise on the highway.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
anotherslowlnf
09-29-2015 03:52 PM
Adiaz1ss
09-26-2015 11:51 PM
roth
09-26-2015 12:16 PM
Quick Reply: New IC Pump NEED HELP!
