New for me setup. Easy safe and good on gas.
2007 Cobalt ss SC ZEX 55 Shot Dry
2.8 Intense-Racing Interchangeable Pulley system
60# Injector Wiring Harness 18.0PSI 7.0k RPMs
Devils own Meth/Water Injection M5 Nozzle
FLW 265 HP 235 TQ AF 11.8 all the way till 7000
FLW 310 HP 270 TQ with 55 Shot.
Stage 5 Intense tune. 1 step colder ngk IRIDIUM
First gear 50% boost cut. Cat removal with o2 bong.
13.6 106 MPH 1/4 mile stock cluth and tires.
Is that 1/4mile with or w/out spray?
This is similar to my setup, cept I did dual pass, cobra HE, etc, instead of meth
I seriously think I want to run a small shot eventually.
nitrous, aside from possibly eventually the Harrop TVS, Seems like the easiest and most cost effective/logical for a daily driver to break into the 12's
I run meth for the street, Nos for track. I have a lot timing pulled on my custom tune so that I can run Mid grade. In florida we run out of high grade every time we have a hurrican. Also I see about 25.6 mpg I did not have to go extream on timing since I am runing a dry shot for extra power. I need the clutch to last a little while longer. By the way thats 1/4 mile is with spray on a cold day and I only got that one time. I usally get 13.8 1/4 becuase my clutch lets lose some times in second gear.
Hmmmm... you're running an Intense tune huh? I hope that works out for you better than others have.
You're making good power with it all, but a 50% boost cut will kill your track times. You need to ramp up the boost in first gear to set yourself up for full boost in second gear. I did a few passes at the the track messing around with it all, and the best pass I made is when the boost was ramped up in first gear. Get a clutch too! Other than that nice setup.
Back at Intense Drag Days of 2006 they had all of their cars down due to problems, and last year their retired Daytona GTP blew up halfway down the track. lol
nb4lock
delete my post if it's deemed inappropriate
They have a new person doing there tunes now he is very conservitated and give sounds advise when he creates your tune. I really dough’s any tune from intense will do any damage to any ones car not at least any more. They recomend only 2.8 pulley max with a 7k limiter now. I have seen a few cobalt’s have issue with an intense tune in the past but it was from a mechanical issue on the car IE Water pump stopped working or to small of a pulley and to high IAT temps. every ones trying to push way to much out of there blowers, best thing to do get a nice running tune with 60 lb injectors and make the horsepower with a second power adder IE nitrous.
roth
09-26-2015 12:16 PM
