New ride and Set up have some questions
Hello,
05 Cobalt SS SC
My question for now is I have 2 reservoirs for my zzp heat exchange, but it doesn't appear there is a pump well at least the reservoir that is usually to the right of the supercharger right upfront isn't there. There is definitely some things done to this car and I just don't know if that is how it is built to run like that or not and I definitely don't want to mess anything up! Any ideas anyone?
Thanks
05 Cobalt SS SC
Thanks
can you take a pic of the engine bay and upload it? you might have to load it through photobucket. Pictures do the guys on this site a lot more justice than trying to explain. Go for the heat exchanger as well as the end of belt/snout end of the blower, you can probably get some good info afterwards.
Welcome to the forums man.
https://www.google.com/search?q=coba...%3B1600%3B1200
just follow that link and you will know exactly what I am talking about! Thanks for the help!
that is the filler neck for the supercharger intercooler system in front of the blower. the resiovior on the drivers side by the fuse box is for the engine coolant. if there is one on the passenger side rear of the engine bay that is an option b, which is for bleeding air from the intercooler system. but if you have the filler neck in front of the blower then you probably don't have that. you have a pump, it is right down in the front between the radiator and the oil pan, mounted on the block.
Thats what she looks like
Last edited by CarbonFiberCobalt; 09-25-2014 at 11:11 AM. Reason: Automerged Doublepost
