NEW Twin Screw Dyno Result
Mase just looked at your logs there. They are roughly what I was seeing more or less when I was tuning it. I did notice that on the top end of that pull the 11.5 A/F ratio and the fact that the max timing was at 19*. There is some more to be had out of it once the A/F ratio is finished being tweaked. I also managed to run 21* timing up top on 93 octane without methanol as well, but my IAT1's were at 97* and my IAT2's were 154* because it was around 95*-100* in the dyno area and humid as hell. I just looked at my logs and it seems I was moving just a bit more airflow past the MAF and was at 21.3PSI as well on that pull. On the street I was seeing 134*-143* IAT2's after consecutive pulls and 24PSI though.
The fact that you are choking the exhaust with that shitty stock manifold is holding back some serious flow. Great numbers overall, and I know 300+ would be had right there if the manifold was swapped out for a nice header!
You just might get to see it up close and in person if you are lucky. I might even take you for a drive if I keep mine.
videos would be sweet
and there no where near maxin out those injectors so the pully size is endless
Last edited by C0baltWithM0ds; 04-14-2008 at 04:38 PM. Reason: Automerged Doublepost
#37
As for the injectors, there is still some play there, but not a whole hell of a lot.
#39
Everyone knoww that if the TVS never came around everyone would be excited about this and would be all over it. Its nice that you guys finally got to about what you wanted to reach with it. Congrats nice numbers
#47
Id like to see a full dyno on this, these half dynos to 5 or 6k arent proving anything, tune the thing to 7k and lets see what it can really can or cant do, this speculation isnt selling anything
#48
