NEW Twin Screw Dyno Result
Old 04-14-2008, 05:40 PM
  #51
lsjwannabe's Avatar
crank pulley/s/c at rpm = sc rpm
Old 04-14-2008, 06:09 PM
  #52
2K5SS/SC?'s Avatar
Friggin fire alarm going off is why I'm still awake. Just found my old email from Lysholm, and it states 15000rpms is the max for this blower. So technically we are 297rpms over it's max. Now, I'm not sure if that is max continuous rpms or max rpms period though.
Old 04-14-2008, 06:11 PM
  #53
Jumpin Fool's Avatar
Cool
Either way = not good
You wanna blow another one?
Old 04-14-2008, 06:12 PM
  #54
TVS_SS's Avatar
Dont forget.. 15000 rpms on the large rotor means 25000rpm on the small rotor!!
typical ball bearings dont like that very much
Old 04-14-2008, 06:14 PM
  #55
2K5SS/SC?'s Avatar
WTF? Small rotor... large rotor...? Are you talking about the gearing because both rotors are the same size.
Old 04-14-2008, 06:18 PM
  #56
TVS_SS's Avatar
one rotor is 5 lobes one is 3 lobes... yes they are close in size, but one spins significantly faster than the other... thats the WHOLE POINT to a screw type.. 'internal compression'
(different screws have different ratios.. like 6/4, 12/8, etc.. but all in all, they will have a ratio between them)
The TVS uses the same number of lobes on each rotor, its 4/4, which means the rotors spin the same speed and its still a roots style with no internal compression
Old 04-14-2008, 06:20 PM
  #57
Talking
Crack Kills!!!
Let'em go 2K, he's obviously the authority on the TS
Old 04-14-2008, 06:21 PM
  #58
2K5SS/SC?'s Avatar
Got you. It's 2:19AM here, I'm not really thinking straight after the firealaram. I really need to go get some sleep!
Old 04-14-2008, 06:25 PM
  #59
TVS_SS's Avatar
Originally Posted by Jumpin Fool
Crack Kills!!!
thanks for tellin him to lay off me..
Old 04-14-2008, 06:31 PM
  #60
2K5SS/SC?'s Avatar
Er...? I'm not on your case, I was just confused for a moment.
  #61
TVS_SS's Avatar
i know your not...
jumpin fool thought you were
Old 04-14-2008, 07:14 PM
  #62
Raven SS's Avatar
Originally Posted by Blown 4-banger
That wouldn't have much to do with injectors. The injectors actually spray into the head its self. They don't even touch the manifold.
funny guy...i'll brush that one off since u are pretty smart but since ur not educated on the fact that our intake manifold is very restrictive and when boosting that much the restriction is causing higher temps and higher temps are causing running leaner which is requiring us to run a bigger injector..so yea..the intake mani has everything to do with injector duty cycle...
Old 04-14-2008, 07:17 PM
  #63
INFE's Avatar
well they will def make at least 300whp when they get a nice long tube header on there. Thats not to bad, but whats the smallest pulley that you can run with this supercharger??? The TVS with the 2.9 pulley is making about that same HP with more TQ though.
Old 04-14-2008, 07:20 PM
  #64
Dayta's Avatar
wow nice!
Old 04-14-2008, 07:21 PM
  #65
Raven SS's Avatar
tvs with 3.1 u mean...i believe this is the max they can spin it(from the other threads) and the rest is going to be tuning and supporting mods..
Old 04-14-2008, 07:40 PM
  #66
*TRIX*'s Avatar
Nice numbers and I loved that idea from the start but For 2 gs you can build your own turbo kit no offence to the twinscrew but that's mad pricey
Old 04-15-2008, 12:09 AM
  #67
2K5SS/SC?'s Avatar
Nope, he was right with the 2.9! Wrong TVS tester.
This is true. Thus, the reason why I have a perplexing dilemma on my hands. I have an offer on the table for my twinscrew that will allow me to go turbo if I choose to do so. Plus, Hahn is looking to offer a tuner essential kit for their 20G setup which would be perfect so I could finish the rest myself.
Old 04-15-2008, 12:42 AM
  #68
INFE's Avatar
idk man i just can see myself going turbo. I love the supercharger idea because its so different, but on the other hand i am not to happy with the numbers that both superchargers are putting out. So idk i guess anythings possible.
Old 04-15-2008, 07:59 AM
  #69
2K5SS/SC?'s Avatar
I think once the guys with the 2.75" pulleys on the TVS start releasing their fully tuned numbers that might change. I'd be willing to be 325-350 will be had with the TVS, and that 315-325 could be had with the twinscrew. While not nearly as impressive as some of the turbo builds, this will satisfy most people's desires. My real issue is that I finally got the car running damn near perfect and pulling crazy hard right before I deployed with my 2.6" pulley and methanol injection. I just don't want to ruin that, but the quest for more power is still there for some reason. It's an addiciton I swear! All it takes is for one of my buddies to put a half car on me, and then I'm back at it all over again!
Old 04-15-2008, 08:59 AM
  #70
Bannned
ColeJJones's Avatar
dont forget the hella low iat2s
Old 04-15-2008, 10:16 AM
  #71
2K5SS/SC?'s Avatar
Oh yes, we can't forget about those "hella" low IAT2's! Cali Bro!
Old 04-15-2008, 11:08 AM
  #72
Rent me! per hour
Area47's Avatar
you really have no idea how picky this motor is on tuning do you.
Old 04-15-2008, 11:15 AM
  #73
lsjwannabe's Avatar
nope, not at all
Old 04-15-2008, 11:29 AM
  #74
Rent me! per hour
Area47's Avatar
you don't count
  #75
lsjwannabe's Avatar
thats true lol
Quick Reply: NEW Twin Screw Dyno Result
