NGK BKR7E iridium equivalent? Or general plug discussion.
There is no need to replace copper plugs that often even wtih meth. I have been running atleast 60% meth on my bkr7e's for 25k miles. they still look fine. I will replace them when I bring the car out this spring just because.
unless you are pushing about 400whp, you do not need 2 step colder either.
John I got a quick question, you go to colder heat ranges to reduce spark blow-out from increased boost pressures correct? So since I will be dropping to a 2.7 but with a ported head, I will have less boost pressure. Should I stay in the one step colder heat range that Im in right now?
I never said every oil change. I referenced possibly every other oil change, mainly in reference to pulling and at least checking them.
I'd rather just switch to iridium and lose the concerns of doing such.
I have been running the BKR7E lately and typically change them out every other oil change (every 12 - 14K miles). When I change them I check them out and by that time the gap has usually opened up about .003 - .004 so they are definitely due at that time. I usually gap my plugs to about ~.037. I ran Iridiums before, but when I switched to a smaller than 3.0 inch pulley the Iridium gap had to be closed alot more so I swapped to copper plugs so I could keep a wider gap.
I pay 14 each for iridium EX plugs. The stock plugs with stock or stage 2 GM last forwever. Push the envelope with TVS or tune or whatever, not a surprise the plug has shorter life...5 k is a little short imho you can find this information here with the search button:
Spark Plug references.
________________________________________
NGK BKR6ES *STOCK heat range* <-- STOCK Plug
NGK BKR6E "V-Power" *STOCK heat range*
NGK BKR6EGP Platinum Plug *STOCK heat range* BKR6EGP NGK G power Platinum alloy stock heat range stock # 7092
NGK PFR6T-10G "Laser" Platinum *STOCK heat range* race plug
NGK BKR6EIX Iridium *STOCK heat range*
Autolite 3922 Copper Plug *One Range Colder*
NGK BK7RE Copper Plug *One Range Colder*
NGK BKR7E Iridium Plug *One Range Colder*
BKR7EIX NGK IRIDIUM one heat range colder stock # 6664 14 BUX Each in Canada
BKR7E NGK REGULAR V POWER? Stock number #6097 says to use 4644
Cheaper $
NGK BKR8E Iridium Plug *Two Ranges Colder*
NGK BKR9E Iridium Plug *Three Ranges Colder*
Denso Iridium IK24 *Two Ranges Colder*
Denso Iridium IK27 *Three Ranges Colder*
Stock Gap is 0.45"
PSi-Fi Pulley Kit Recommendation gap is 0.28"
Intense-Racing GM-MAF-T/42.5lbs Injectors/2.8" Pulley Gap recommendations is 0.45"
South Florida Pulley Headquarters suggested NGK BK7RE gap is 0.35"
For those of you running 2.8" or below. TWO RANGES COLDER IS RECOMMENDED.
http://www.ngk.com/
Cheaper $
Stock Gap is 0.45"
http://www.ngk.com/
I wouldn't recommend going to two step colder plugs unless the car is strickly a race car, or you are running TVS or a 2.7 or smaller pulley with a very aggressive tune.
Running a spark plug that is too cold will hurt performance just as bad as running a plug that is too hot.
Also, BKR8E are hard to find. you really have to hunt around to find them. Most people that go with a 2 step colder plug usually go with the BKR8EIX which is the Iridium two steps colder and is easier to find.
Thanks a lot for you help, I think im just going to stick with the BK7RE. Anything suggestions on where i should buy them from? I was thinking of just ordering them from Ottp.
agentirons
10-16-2015 02:11 AM
Delta coupe
09-30-2015 08:11 AM
