nitrous?
nitrous?
hey guys im looking into hookin up the ott nitrous kit. im just wondering if im going to have to have any supporting mods for it i want to run a 60 shot. will i need any other supporting mods? all my mods are in my signature and will i need to retune it?
hmm... you might run out of fueling w/ the 2.9 and spray at the top end if your still on 42#
ask OTT though im sure they will help you
generally its meth or n20 not both.
HE isnt necessary
retune is.
HE isnt necessary
retune is.
It will be ok until it breaks the weakest point. You could get 10 passes or 100 bottles through it. As far as injectors go, as long as you are spraying a wet kit, bigger injectors are not necessary. The kit itself add's enough fuel for the kit as long as you pay attention to the jets you are putting in. The only support mod for a nitrous kit on these cars is a window switch for activation of the kit because cobalts are a "drive by wire" set up. Meaning there is not a throttle cable.
There is nothing wrong with using methanol injection and nitrous. I run both and I recommend it. The Methanol Injection will help increase the octane which is much more safe when using nitrous.
Non Authorized / Non-Supporting
Think of a water methanol injection system as a massive octane enhancer. Which is simply slowing down and stabilizing the burn rate of the fuel.
Let me know if you have any other questions.
Rodney
ncstateredline
09-10-2015 07:22 AM
