Nitrous question..
Old 03-30-2011 | 04:29 AM
Josuizzle16's Avatar
Nitrous question..
Ok I don't have all of this on yet but I do already have it and plan on installing all of it by the end of the month... I have a 2.8 pulley, 80lb injectors, cold air intake, 3 inch catless exhaust, ZZP S3 HE, header, and I think thats it... Anyways my nitrous question.. I'm planning on buying it this weekend.. But my brother think I'll blow up the engine?? I don't think so but I just want some opinions on this??? How much can the stock engine take?? My plan was a 50 shot... Thanks.
Old 03-30-2011 | 10:47 AM
Black SS 07's Avatar
less boost 2.9 or 3.0, tune and 50 shot dry, 75 wet.
i would personally get a header/dp if you dont have one. you can gain safe power for about the same price. $400 for a cheap main line kit plus ~$40-$50 per fill. so in the end you will probably spend a easy $1000 by the time you give it up. $1000 can go towards a header/dp, good tune and cooling mods
real mods > n2o.
Old 03-30-2011 | 01:53 PM
I have a header and downpipe too
Old 03-30-2011 | 01:57 PM
Bl4des's Avatar
you will be fine on a 50 shot and a 2.8 or you can put a 3.0 pulley back on and run like 100 shot and should still be safe
but i hope more people chime in i never ran n20
Old 03-30-2011 | 02:05 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i did 23 bottles through my car on varying 60 shot, 75 shot, and 100 shot with race gas. all on the 2.9 pulley. 50 shot would obviously be the safest. a nice wet kit will provide you reliable power on the 50 shot
Old 03-30-2011 | 02:19 PM
Staged07SS's Avatar
Administrator
Administrator
I was going to say PM/Search ^Blazin07SS or Italianjoe.
Both have run nitrous on their LSJ's in the past.
Old 03-30-2011 | 03:19 PM
BIG SS TC's Avatar
with nitrous i believe all kits will say its safe to run 1/2 of your Stock engines hp output(not asfter mods unless they are internals and fuel). so stock if it was 100hp u should be safe with 50shot
Old 03-30-2011 | 04:08 PM
Texas SS's Avatar
I am currently doing same and i have been talking to josh(blazin07) and hes been helping me with all my nitrous questions. Oh btw i will be running 2.9, 42#, trifecta/hp gm stage 3, with full supporting cooling mods planning to spray a dry 50 then go from there and my nitrous kit is a custom kit
Old 03-30-2011 | 04:20 PM
Awesome thanks everybody!!
Old 03-30-2011 | 06:14 PM
StreetDreamz's Avatar
My car spent an entire weekend on C16, a 150 shot, and a 2.7 pulley. On the 100% stock motor. By an entire weekend I mean 30lbs. worth. Pick a shot and have fun! I say you're fine to run around all day on a 75 and with a good tuner you will net ~335whp/340ft.lbs. with all those mods plus a 75 wet shot from NX (wheel rated hp shot).
My past two Redlines lived on nitrous. I even used to a run a 100 shot on a 2.8" Harrop with little more than new head studs and pistons. Be warned though. With the extra torque a mere 75 shot would deliver (about a 30% increase and almost 50% over stock), you will probably want a better clutch. A dual stage (75 shot + 75 shot, landing me around 400 ft.lbs. we estimate) did this to my stock clutch on my first redline about 5 years ago at 4,500 miles on the car:
A few weeks after getting my Spec Stage 3+ in and repairing the trans, the diff pin shot out the bottom of the trans and I had to buy a whole new trans. So be warned.
And something else inside the trans shifted at the same time, breaking more ****.
It did look pretty though:
Old 03-31-2011 | 12:09 PM
BIG SS TC's Avatar
i had nitrous on my stang which was an 02 v6 auto lol and i hit 13.6 at like 101 on the 1/4 mile. had 250 hp and 300tq i believe, cant rember tq)
06blackg85ss
83
01-18-2017 05:35 AM
Decepticon06ss/sc
10-16-2015 10:24 PM
TylerJHowell
09-21-2015 07:47 PM
ncstateredline
09-10-2015 08:22 AM
Brian MP5T
Nitrous Oxide
18
11-20-2005 07:53 PM
