No Catalytic Converter ?
Old 01-30-2006, 10:48 AM
360 L337 User
R33P3R007's Avatar
For everyone without a cat? what are you doing for the CEL. I had just been dealing with it until yesterday. I found directions on how to make an O2 Sim online so I thought I'd try it. I cleared my code which was oxegen insufficient engine bank 2 or something.
Made the o2 sim using 2 non fouling spark plug adapters. take one and screw it into the downpipe, then take the other and drill it out to 1/2 and put it on the sensor. then put them together. it just makes the sensor sit out farther and not get as much of a reading.
I have the HELP part number if anyone else wants to try it, but i don't think it is working.
so anyway. afer a few miles like 30-40 I get a CEL. check it and it is the lean code. I clear it again to see if it comes back on, but it hasn't yet in almost 100 miles.
But last night on my way home my friend and I were doing a little messin around, after my 3-4 shift at about 5 thousand i let off, and he said I shot a "HUGE" flame. What can this be from. isn't that rich, not lean.
Should I just take the Sim off and deal with the code until I get the Vibrant exhaust?
Sorry about the long read. hope you can help.
Old 01-30-2006, 11:56 AM
360 L337 User
R33P3R007's Avatar
thanks for the help guys
Old 01-30-2006, 12:00 PM
3fo893013L's Avatar
removed. I'm a *******.
Old 01-30-2006, 12:13 PM
selfinfliction's Avatar
not sure why you're trying some crazy **** like that. you can buy a cheap o2 mil for $10 and splice it in the wires.
no offense but that method sounds dumb as hell
Old 01-30-2006, 12:16 PM
360 L337 User
R33P3R007's Avatar
it works on other cars, I just figured I would try it. it was like 1.89 and until they make one that doesn't need to be spliced in I will just deal with the cel.
Old 01-30-2006, 12:31 PM
Mercury's Avatar
Hey what did you end up dynoing at Evolution?
Old 01-30-2006, 02:08 PM
360 L337 User
R33P3R007's Avatar
I didn't.. it was taking forever and they still had like 10 people so I decided not to. I will next time. and after I get the Vibrant exhaust.
Old 01-30-2006, 02:50 PM
FAST06SS's Avatar
02 sim does NOT work on our cars, or ANY 04 or newer GM for that matter!
The PCM does some intrusive testing and none of the 02 sims can make it happy.
I use the aeroforce gauge and clear the codes with it evry 3 days.
Old 01-30-2006, 02:51 PM
360 L337 User
R33P3R007's Avatar
so just deal with it. but why is it telling me lean and blowing flames? is it trying to fix the lean code, it is stock so it runs rich like everyone else normally.
Old 01-30-2006, 03:47 PM
not true
you're refering to vehicles equipped with CAN and not all gm vehicles are, the cobalt ss/sc is not listed as can compliant either.
Old 01-30-2006, 03:59 PM
360 L337 User
R33P3R007's Avatar
whats CAN. so why am i all of a sudden flamethrowing?
Old 01-30-2006, 05:48 PM
05_Blue_B10WN_SS's Avatar
The flames are no big deal man. Its afterfiring. When people downshift, and they are hearing the "Poping" noise, its the same thing. The only difference is you have no cat, so the flame is going out the tailpipe instead of being stoped by the convertor.
Old 01-30-2006, 05:53 PM
Doc
Doc's Avatar
thats an understatement....as long as your not the one behind his car when it does that
Old 01-30-2006, 06:43 PM
nick11's Avatar
GRR omg you telling me if I remove my cat im going to get a CEL *sigh*
Old 01-30-2006, 07:20 PM
dnbguy86's Avatar
CAN, basically is kinda of controller. If you were going to use a tech2 to check codes at a dealership like mine, you use the CANdi module which stands for controller area network- digitial interface. So its like an advanced form of engine control and management. In other words, you just use the controller to decipher the high speed at which data is travelling along the data bus. Nothing really complicated about it...
Old 01-30-2006, 09:14 PM
FAST06SS's Avatar
A little FYI, you don't need a CANDi module to communicate w/ the PCM
Old 01-30-2006, 09:21 PM
MOD MONEY's Avatar
I think I'm gonna get a high flow cat with 02 sensor bung and get a AEM air/fuel gauge. I think that might be alright.
Old 01-30-2006, 10:07 PM
holy big ****** signature batman
Old 01-30-2006, 10:21 PM
MOD MONEY's Avatar
It takes too long to upload on dial up.
Old 01-30-2006, 10:34 PM
nick11's Avatar
Umm no offense but either you where not responding to my question at all or you speaking to technical for me.
My question was simply if I remove my cat and put a test pipe will I get a cel and will this cause problems? If so can I simply buy a high flow cat to get around this problem?
Old 01-30-2006, 11:28 PM
360 L337 User
R33P3R007's Avatar
it is already hi flow....only last 1/3 actually restricts. yes u will get a code. i didn't remove mine it blew out the back
Old 01-30-2006, 11:34 PM
nick11's Avatar
Ok so if I leave my cat alone and just replace the muffler and the last 1/3 exhaust with 2.5' pipping at my local exhaust shop... I should get a nice hp gain and have my exhaust system not sounding like that crappy corsa exhast....
I also plan on getting the GMPP manifold if that helps at all.
Old 01-31-2006, 08:08 AM
360 L337 User
R33P3R007's Avatar
i would recomentd the replacement of your last 1/3 but not the manifold. but it is up to you
Old 01-31-2006, 08:27 AM
OMGWTFBBQ!!11!!1
corsa is teh roxorz... lol i can't believe people actually thought it sounds good then again, when people bought that wonderful magnaflow rasp maker exhaust, they tried to say there was no rasp
Old 01-31-2006, 09:13 AM
360 L337 User
R33P3R007's Avatar
yeah no ****.. funny huh.
Quick Reply: No Catalytic Converter ?
