obx fuel rail
South Central *********
those are ID 850 injectors injectors. they are a short injector with a long spacer to make them 60mm, the same size as all the injectors used in the lsj (33lb green tops, 42lb black tops, siemens 60lb, motron 80lb, you get the idea). i just added a 12mm spacer to the top of them to allow me to space the rail up higher to clear everything.
