Official Turbo LSJ thread!!!
Old 11-10-2012 | 06:38 PM
  #3051
mexi_loco's Avatar
that's cause you're a hellaflush freak show and you add crack to the corn juice.....
Old 11-10-2012 | 06:39 PM
  #3052
BLAZIN07SS's Avatar
I'm too JDM for you
This car makes me laugh everytime I drive it. I just ask myself how the hell its holding together
Old 11-10-2012 | 07:08 PM
  #3053
EXsoccer1921's Avatar
its not hard to put the power down. really its only going to spin 2nd. 400hp in 3rd isn't going to spin
Old 11-10-2012 | 07:11 PM
  #3054
mexi_loco's Avatar
you say that as you flaunt your slicks and skinnies
Old 11-10-2012 | 07:23 PM
  #3055
i don't have slicks. and the skinnies aren't on the car. but either way thats for the track not the street. a good street tire will hold it. if it spins in second learn how to pedal the car. and i don't mean womping the gas up and down going bwaaaah spin bwah spin bwah spin bwaah shift, booooog.
  #3056
c130aviator's Avatar
Originally Posted by mexi_loco
to be honest, i'm not sure if you completely understand what it would take to get anything more than 400+ hp to hook up on the street. You see what mark (exsoccer) has to do. He's the only one in this thread with more than that. 400-450hp is a great range for a fwd car, especially if you want to daily it. So in essence, it's still an ideal turbo.
that is what I was figuring. I dont plan to go much over 400 I just want the number. Like so many its just a number, its not necessarily going to make my 1/4 any better if I am just burning rubber. I stand by my already paid for 20g and I dont plan on anymore than this. My best shot is coming up as soon as I get my block back. I have 80lb inj, e85, 20g, ported head, and 3 inch turbo back exhaust by Hahn; not to mention the million other things I have added in the process. If this doesnt do it, the 20g is hopeless. At any rate. After I get her back together, the only thing I have left in my personal to do list is cams. Then... done as far as engine goes.
Old 11-10-2012 | 08:20 PM
  #3057
Bad-A-SS's Avatar
Well what kind of tq would the 259 give on a conservative tune? Anyone know
Old 11-10-2012 | 08:22 PM
  #3058
mexi_loco's Avatar
i think you shouldn't place blame on the turbo per say. There's a lot of factors that go into power bands. The tune for instance.....
Old 11-10-2012 | 08:38 PM
  #3059
Right, that is why all the mods I have done is to remove those factors. When it comes time to dyno, it will come down to the tune. Totally agree. Hope the guys here are savvy. They mostly do built LS3 and up engines. A few turbos. Hoping they can pull some ponies out of my cobalt.
Old 11-10-2012 | 08:43 PM
  #3060
Larger turbos seem to give lower tq numers and smaller turbo seem to give more tq but as was mentioned earlier, its all speculation because where is it making power in the powerband? You will see k04 guys making more torque than hp and vise verse' in larger turbos where hp is huge but tq is decreased. Remember though high torque breaks transmissions so a larger turbo making big power with a more conservative tq curve is good for longevity of parts.
Old 11-10-2012 | 09:14 PM
  #3061
Bad-A-SS's Avatar
The more I hear the more I feel like the 259 is better for what I want I mean to be able to run a conservative tune n boost n hit numbers close or above the 400s would be amazing and im sure I could daily it easily. Any suggestions kit wise tho? Per say I buy exsoccers 259 how could I go about getting a whole kit pieced together
Old 11-10-2012 | 09:19 PM
  #3062
BLAZIN07SS's Avatar
I'm too JDM for you
i would not run a 259 on a stock head/cam lsj. that's just me.
i run the ***** off of my car on 25.5psi and it's been perfect
Old 11-10-2012 | 09:27 PM
  #3063
Bad-A-SS's Avatar
Why not
Old 11-10-2012 | 09:32 PM
  #3064
BLAZIN07SS's Avatar
I'm too JDM for you
lag, it's a street car. you want pep. sure a 259 is going to be great up top but only being able to rev to 7200 max on a stock head is making the power band kind of worthless.
Old 11-10-2012 | 09:38 PM
  #3065
Bad-A-SS's Avatar
So your saying a 256et or 252et would better suit me powerband wise which be more streetable
Old 11-10-2012 | 11:21 PM
  #3066
rivaladore's Avatar
I think that's what he's saying. I'm running the s252et and the lag kinda pisses me off sometimes, especially in third gear. Can't imagine what a 259 would be like. Sometimes I think I would've been happier and more content going with a small pulley on a tvs and meth. Might have been less power but more fun to daily drive. I miss the torque down low and having to get my rpms up before my car feels like it has any sort of *****
Old 11-10-2012 | 11:37 PM
  #3067
^this and mine is with a 20g, I make full boost at something like 3300 rpm and it feels like forever compared to my stock supercharger.
Old 11-11-2012 | 12:58 AM
  #3068
Bad-A-SS's Avatar
So how the hell do those guys like blackwiddow get full spool at like 3500-3700rpms with a bigger turbo
Old 11-11-2012 | 01:30 AM
  #3069
terry11's Avatar
You guys need to read a little more about turbos/ turbo set ups, tuning, and little tricks that have been used for a while now that make it easier to make boost early.
Old 11-11-2012 | 07:05 AM
  #3070
BLAZIN07SS's Avatar
I'm too JDM for you
E85 and cram timing down its throat. I hit 25.5psi at 3,700rpm and my s256 is different from the one Zzp sells now. I have a larger exhaust wheel and the 4 inch inlet front cover which slows down spool slightly
Old 11-11-2012 | 08:39 AM
  #3071
i feel bad for you if you see lag on a 252. wtf are you doing, punching in 3rd at 30mph???? i mean **** i only have a .55 turbine on a 74/64 wheel and i don't think its bad at all. at the track i shift from 2nd to 3rd and it literally, is instantly back at a huge amount of boost.
the man said "i want a turbo that at low boost and a conservative tune" (to me is teens to 20psi on pump) "will make 400hp. and then when i upgrade the internals i can turn it up and make 500s". josh dont get me wrong i love your setup. but i don't see what youre doing as low boost nor pump gas.
Old 11-11-2012 | 08:46 AM
  #3072
if you are talking about power enrich fuel multiplier vs rpm in hptuners, yeah my curve looks like a snake. YOu can only toon so much around certain things, there is still going to be some lag.
Old 11-11-2012 | 10:35 AM
  #3073
rivaladore's Avatar
No I'm not punching it in third gear at 30mph. I don't have that much lag, I have no problem breaking the tires loose in second I just want a little more up and go in third without having to wind out second when shifting to third. Its probably not even that bad I'm just used to the car and its craving more.
Old 11-11-2012 | 10:58 AM
  #3074
Bad-A-SS's Avatar
So exsoccer just driving around on the road where do you tend to see full boost at when it was set to 20psi?
Old 11-11-2012 | 11:30 AM
  #3075
BlkWdoSS's Avatar
a lot of money, a lot of time, experimental techniques and a **** ton of knowledge, I dont have time at the moment, but if you will pm me, Ill explain a ton of things to you if I can
Quick Reply: Official Turbo LSJ thread!!!
