Official Turbo LSJ thread!!!
Old 01-14-2013 | 06:06 PM
  #3551
EXsoccer1921's Avatar
Originally Posted by Import Reaper
I just wanted to make sure I wasn't missing anything. So I should be fine running about 400whp with that setup I said earlier and then if I want more power look into getting sleeves and girdled short block is what your saying basically? ok thanks exsoccer appreciate the info.
sleeves or girdle.
also i forgot about it till he posted. if you feel like shipping your block mr b can sleeve it for you with a better than stock, stock replacement.
B i know you've installed at least one set. anyone thats making some good power?
Old 01-14-2013 | 06:13 PM
  #3552
mrbelvedere's Avatar
sleeves or girdle.
ive got 2 blocks done building one them then I can start on mine and 1 set sent to canada
Old 01-14-2013 | 06:27 PM
  #3553
Import Reaper's Avatar
sleeves or girdle.
Oh ok sleeves or girdle. Ok well I gotta wait til my car doesn't become my DD anymore haha. Does anyone know why I can't get wiseco pistons for my car and have to get the off brand from zzp that are even more expensive haha?
Old 01-14-2013 | 06:35 PM
  #3554
j.e. pistons isent an off brand and its not an off the shelf piston it is a custom piston made for zzp you can get wiesco pistons for made for around 160 a hole or get a set of diamonds for 400 which are just as good add around 150 for rings
pistons arent just drop in either
GDS
  #3555
let me know how they turn out. are they just 2.0L sleeves or 2.1L as well. what is it like 86mm for 2.0 and 88 for 2.1? next time i rebuild i'm getting rid of the 2.0 since i'm still on a gen 2 block. want to go with a gen 3 2.1. but i'm doing some other stuff as well. so i wouldn't mind having some of these sleeves for that extra security.
wiseco pistons are designed for the lnf to work with the DI. the "off brand" ones you're speaking of are JE pistons. you can run JE or Diamond in the lsj. I'm running 9.0:1 JE's with Pauter rods. bullet proof.
Old 01-14-2013 | 06:41 PM
  #3556
I think its going to take a different type of sleeve for a gen 3 block I would realy like to heck one of them out
GDS
  #3557
TStone's Avatar
beat me too it
Old 01-14-2013 | 06:43 PM
  #3558
another thought is you can run 2.2 rod and piston combos in an lsj
GDS
Old 01-14-2013 | 06:56 PM
  #3559
FF_ace's Avatar
Import no that sounds spot on. off the top of my head though i don't remember at what boost level and power the stock sleeves tend to fail but i would look in to that. 500hp on a 256 is going to be around 27-30psi. while the pistons and rods you're doing will get you over that, thats a lot of pressure for stock sleeves. but like you said. for now you just want to run 400. which is more than do able on stock sleeves. but before you turn it up i would start saving money and look in to a girdled short block, or just staying around the 400whp level
jonathan is correct in answering your original question. "if you left the core/block stock, internals stock and added the trubo setup would it make more power then a fully bolted LNF"
yes a turbo lsj will make more power than a bolt on lnf. a bolt on lnf on e85 or an e blend tune will top out around 370.
but with that comes my post about turbo size lol. the ko4 has a crazy soon powerband. if they hook up, they're gone. thats where choosing the right sized turbo really plays a major role. sure you can compare peak power all day long. but i'll take a 375whp car that sees full boost at 3,200 rpms peak power at 4k and carries it out to 7500 over a car that makes 420whp but doesn't hit full boost until 4100 and peaks at 5,500 or 6000
(those examples are not lnf/lsj/ko4/etc
specific. just power band in general)
im one of those guys with a 5857 on a .63 ar I dont hit full spool till 4400-4500 rpms. Thought about running a .48 ar but dont know how much it would hurt the top end
And mine is dbb
Old 01-14-2013 | 07:09 PM
  #3560
isn't the 2.2 an 88mm bore?
i thought 2.0 was 86x86 bore x stroke. 2.2 was 88x86. and 2.4 was 88x88
Old 01-14-2013 | 07:32 PM
  #3561
you have .043 difference in rod length the lsj is shorter
you have a .338 differnece in stroke lsj shorter
both have 85mm to 86mm bore
and the sport compact build book 3rd edition they recommend and put a set off lsj rods and diamond piston combo as a hop up to a 2.2 so why cant you go backwards
GDS
Old 01-14-2013 | 08:35 PM
  #3562
nwss's Avatar
you have a .338 in stroke
and the sport compact build book 3rd edition they recommend and put a lsj rod and piston combo as a hop up to a 2.2 so why cant you go backwards
You must be trolling.......
Old 01-14-2013 | 08:36 PM
  #3563
nwss's Avatar
Decided to put the intake mani, spacer, and tb on today. Tomorrow I finish everything up....hopefully
Old 01-14-2013 | 09:06 PM
  #3564
klutch814's Avatar
this thread needs moar pics lol
Old 01-14-2013 | 09:32 PM
  #3565
nwss's Avatar
Ill take more tomorrow
Old 01-14-2013 | 09:51 PM
  #3566
ok thanks exsoccer and Mr. B good info for me to use towards build. hopefully be one of you guys soon haha
Old 01-14-2013 | 10:33 PM
  #3567
no trolling fact
GDS
Old 01-14-2013 | 10:38 PM
  #3568
nwss's Avatar
no trolling fact
GDS
Well I sure hope you wouldn't put stock 2.2 rods in a lsj
Old 01-14-2013 | 10:44 PM
  #3569
LAAAAAAAAAAAAAAAME
no trolling fact
GDS
and i missing what GDS is? lol
  #3570
no use a 2.2 aftermarket rod and piston combo hell you can get a set wiesco pistons and eagle h beams for 800 or less
GDS
Old 01-14-2013 | 10:45 PM
  #3571
he doesn't literally mean 2.2 rods noobsicles. 2.2 rods like Pauter or eagle rods. although idk about eagles quality..
Old 01-14-2013 | 10:47 PM
  #3572
i'd rather just go with a gen 3 block and just get rid of my old 2.0 stuff instead of trying to mix and match. i'll leave that to my suspension damn frankenstein
  #3573
ive used eagle plenty in sbm@13to1 and higher they are good stuff not mention gm used them in 1400 hp engines
GDS
Old 01-14-2013 | 10:50 PM
  #3574
if I had the money for a gen3 block oh lawdy
GDS
Old 01-14-2013 | 10:51 PM
  #3575
c130aviator's Avatar
Ohh Kay...
Quick Reply: Official Turbo LSJ thread!!!
