Official Turbo LSJ thread!!!
Old 02-07-2013 | 11:19 PM
  #3951
c130aviator's Avatar
here is what i have.
Turbosmart Blue Silicone Turbo Tubing Hose Vacuum 4mm 5 32" 10' Wastegate BOV | eBay
Old 02-08-2013 | 02:27 AM
  #3952
jonnymerk's Avatar
Originally Posted by tylerman683
Debating to go turbo bro!!! N how much more will e85 give me
If you can afford it and do it properly the first time round then I highly recommend it. Different strokes for different folks. Even with all the headaches Ive had I don't the change over. Turbo is tons of fun and does things and makes blessed noises the s/c just couldn't.
Old 02-08-2013 | 08:05 AM
  #3953
tylerman683's Avatar
Haha ok n yea that's the thing if I can afford it I just want over 300hp is all
Old 02-08-2013 | 03:59 PM
  #3954
EXsoccer1921's Avatar
2.7, cooling mods, a nice intake and exhaust, 80s and e85 will net you 300 on the m62
Old 02-08-2013 | 09:31 PM
  #3955
Cmyler34's Avatar
What size pulley do I need for my turbo swap? They didn't send one in my kit..... Stupid people. Anyone know? For the Hahn kit.
Old 02-08-2013 | 10:17 PM
  #3956
Cmyler34's Avatar
Belt* not pulley
Old 02-08-2013 | 10:19 PM
  #3957
mexi_loco's Avatar
you'll need the belt off a 2.2, as well as the idler assembly.
Old 02-08-2013 | 10:21 PM
  #3958
Go to auto zone and ask for a 2009 cobalt ss turbo belt. Do you need a welded alternator? I have one.
Old 02-08-2013 | 10:28 PM
  #3959
Cmyler34's Avatar
Okay thanks man ill do that, they sent me the wrong belt it's way to small and it's only 4 ribs not 5.
And no I have the alternator already!
Old 02-08-2013 | 10:30 PM
  #3960
Bad-A-SS's Avatar
I might need one there turbo duckie
Old 02-08-2013 | 10:31 PM
  #3961
Cmyler34's Avatar
Old 02-08-2013 | 10:41 PM
  #3962
Cmyler34's Avatar
Oh also, you know the oil feed line for the turbo? Where in the hell is it located? I have everything on but I can't seem to find the plug. Any suggestions?
Old 02-08-2013 | 10:46 PM
  #3963
Cmyler34's Avatar
Old 02-08-2013 | 11:47 PM
  #3964
klutch814's Avatar
about these vac lines..lol
Old 02-08-2013 | 11:57 PM
  #3965
60 bucks shipped, its welded up by a fab shop, Nice piece. Works great, just need shorter bolts. you need bolts that are the same length as the ac compressor bolts. I bought mine from mongorat.
Oil feed line plugs into a "-an" fitting on top the turbo cartridge, curves around and plugs into the block at one of the oil galleys in the back of the block , there are 3 of them. I used the far right side closest to the turbo. They are a pain to get out but use a giant allen wrench and they will come out. You must have the turbo, and other stuff off and out of the way. I had the water crossover tube off when I pulled mine so that there was no restriction to the plug.
what else you confused about?
Old 02-09-2013 | 12:02 AM
  #3966
klutch814's Avatar
im a bit retarded at this lol.
Old 02-09-2013 | 12:10 AM
  #3967
no problems man, ask away and remember there is most of this covered here in this thread. Just do a search up top of this page on this thread. Also search google images for bov diagrams or wastegate boost controller diagram. Its not hard at all.
Old 02-09-2013 | 12:13 AM
  #3968
klutch814's Avatar
for the most part i would keep it how i have it right? wastegate to bc to turbo then where does the side port of the wastegate go?
Old 02-09-2013 | 12:20 AM
  #3969
t it back into the turbo like this.
the manifold to bov is a seperate system all together. Leave it tubed from bov to manifold.
Old 02-09-2013 | 12:25 AM
  #3970
klutch814's Avatar
okay i see. ill need another T then.
Old 02-09-2013 | 02:22 AM
  #3971
Cmyler34's Avatar
Okay I'll try it.. One more thing. Did you see my post about the coolant lines on our turbo ? Do we use them or no?
Old 02-09-2013 | 10:06 AM
  #3972
I dont know anyone on a turbo swapped cobalt ss/sc that is using the coolant portion of the cartridge. Oil provides enough cooling per Bill Hahn Jr. (talked to him on the phone directly)
Old 02-09-2013 | 10:46 AM
  #3973
Cmyler34's Avatar
That's what me and a friend were saying, but or the belt I bought the one you told me too but it's 5 ribs and the tensioner pulley is 6 ribs. Does this matter ?
Old 02-09-2013 | 10:53 AM
  #3974
doesnt matter, I have a 5 rib LNF alternator and serpentine tensioner, 6 rib crank, 6 rib ac compressor. TC/LNF serp belt. When you install everything you barely notice the 1mm of space extra on the two 6 rib pulleys.
Old 02-09-2013 | 10:57 AM
  #3975
Cmyler34's Avatar
Ahhhhhh okay good! Thanks for all the help! Builds done now once I get the belt on!
Quick Reply: Official Turbo LSJ thread!!!
