Official Turbo LSJ thread!!!
Old 02-21-2013 | 01:02 AM
  #4176
ssyellow's Avatar
Jumping in here to ask a quick question. Debating what I want to do with my Redline in the future (Get into another SS TC again, different car, etc). For those of you running turbo swaps on an LSJ without the G85 LSD, how bad is it?
Old 02-21-2013 | 01:13 AM
  #4177
c130aviator's Avatar
i dont have one and its not that bad. tq steer is worse in supercharged cars. But if I had 700 bucks to buy one from mongorat that would be on my list after fuel, cams, bigger turbo. in that order.
Old 02-21-2013 | 01:19 AM
  #4178
ssyellow's Avatar
So you're not one-wheel peeling around when you get on it? I know the viscous method probably isn't ideal LSD for straight line performance but I was worried if I eventually did end up turbo swapping the tupperware it would have traction issues and what not.
Old 02-21-2013 | 01:22 AM
  #4179
EXsoccer1921's Avatar
i don't have an lsd....
Old 02-21-2013 | 01:43 AM
  #4180
ssyellow's Avatar
Nice to know. Generally speaking, what kind of 60's do you get on slicks/radials/whatever you use?
Old 02-21-2013 | 01:59 AM
  #4181
Dart_SI's Avatar
lsd is more for handling than straight line traction.
Old 02-21-2013 | 02:07 AM
  #4182
ssyellow's Avatar
Quite true, words cannot describe how much the Redline sucks in a turn when you give it power as compared to my SC with the limited slip and TC in the past. I was just curious if it played much of a role in a higher powered one while going straight.
Old 02-21-2013 | 02:16 AM
  #4183
1.9 on these radials. 1.7s can be had on slicks. with the right suspension power and tire 1.6s
Old 02-21-2013 | 06:33 AM
  #4184
rivaladore's Avatar
I have an LSD and second gear still must be feathered in order to maintain traction.
Old 02-21-2013 | 08:45 AM
  #4185
mrbelvedere's Avatar
wrong
Old 02-21-2013 | 10:43 AM
  #4186
MP Cobalt's Avatar
LSD helps overall any kind of traction. With an open diff you can get 1 tire fires when with an lsd both tires will spin.
Old 02-21-2013 | 10:51 AM
  #4187
weld up the spider gears, full time straight line traction.
Old 02-21-2013 | 10:54 AM
  #4188
zrated89's Avatar
Guys quick question. I'm getting ready to buy and lnf alternator from Mongorat. Does anyone know if the lnf tensioner is the same as the 2.2? Also what about the idler pulley ? I know ill use the lnf belt too. I already have a 2.2 alt but it's a two pin connector
Old 02-21-2013 | 10:56 AM
  #4189
idler is connected to the tensioner, lnf alternator is what I am running, it will work, l61 idler is the same as the lnf and either one will work.
Old 02-21-2013 | 10:59 AM
  #4190
here is one for sale. Chevy Cobalt SS 2 0L Turbo Engine Belt Tensioner Serpentine 2008 2010 | eBay
Old 02-21-2013 | 11:07 AM
  #4191
zrated89's Avatar
Thanks man called my Gm dealer and the 2.2 is the same as the lnf tensioner. No idler listed. Le5 is different. So technically all I need is lnf alt, tensioner and belt. Cool
Old 02-21-2013 | 12:02 PM
  #4192
an idler is a wheel that is just there to "idle" another way to route the belt to keep as much belt as possible on an adjacent pulley. In our case the idler is the tensioner. I used an l61 tensioner/idler with an lnf alternator with an l61 belt.
Old 02-21-2013 | 03:02 PM
  #4193
zrated89's Avatar
Yea but we have an idler stock. And our tensioner sits up top. After doing research though the lnf/l61 tensioner goes in the spot where our idler is. Thanks man
Old 02-21-2013 | 06:05 PM
  #4194
gotcha, i never familiarized myself with the supercharger. I took it off the car just a few months after I bought it.
Old 02-21-2013 | 06:27 PM
  #4195
My first 400hp pull. 20psi
Last edited by c130aviator; 02-21-2013 at 06:49 PM. Reason: might help if I put up the video with it.
Old 02-21-2013 | 07:07 PM
  #4196
SylverSS/SC's Avatar
Lol so much powa, your wiper committed suicide!
Old 02-21-2013 | 07:08 PM
  #4197
I heard some spark blow out happening
Old 02-21-2013 | 07:10 PM
  #4198
Hood comitted suicide; already have a brand new oem hood on the car that wont peel like a banana. Amazon had oem steel hoods for 132 with free shipping.
Old 02-21-2013 | 07:29 PM
  #4199
yeah they are .032, need to drop them down a bit.
Old 02-21-2013 | 07:30 PM
  #4200
Cmyler34's Avatar
my tune is sitting at 18 degrees timing 22 psi and making 411 as I sit right now.
What fuel pump are your running?
Quick Reply: Official Turbo LSJ thread!!!
