Official Turbo LSJ thread!!!
Old 03-08-2013 | 09:41 PM
  #4526
Bad-A-SS's Avatar
Did you post anymore vids
Old 03-08-2013 | 10:04 PM
  #4527
rivaladore's Avatar
Originally Posted by nwss
Yeah I noticed my boost gauge is retarded at half throttle. Maybe ill switch to a hks haha I want more ricer!
Yeah I do that to hotties all the time haha and they always look!
Wasn't giving me issues during partial throttle.......only when I would let off the gas after being partial throttle in fourth/fifth gear. Went away after I switched to the tial q. Zzp's bov is just a paper weight for me right now.
Old 03-08-2013 | 10:58 PM
  #4528
nwss's Avatar
Yeah maybe ill look into the tial
Old 03-08-2013 | 11:03 PM
  #4529
zrated89's Avatar
not yet man tuning her tom but on only 12 psi she feels like my tvs setup did lol
Old 03-09-2013 | 12:23 AM
  #4530
jonnymerk's Avatar
so I'm doin k1 rods and diamond pistons and balance shaft delete....all because of a few spun rod bearings Would luv to sleeve and go all out but this was unplanned and expensive enough as is.
Old 03-09-2013 | 01:28 AM
  #4531
Bad-A-SS's Avatar
Yeah I cant wait to see my PT5558 can do with just 15 pounds
Old 03-09-2013 | 02:09 AM
  #4532
nwss's Avatar
Can't wait to have this damn 252et 20+ psi
Old 03-09-2013 | 09:08 AM
  #4533
MP Cobalt's Avatar
^ Hey does your tial bov still stay open at idle? I'm thinking about taking mine apart and shimming it
Old 03-09-2013 | 09:23 AM
  #4534
zrated89's Avatar
my 50mm doesnt at all
Old 03-09-2013 | 09:54 AM
  #4535
rivaladore's Avatar
My tial q hangs open at idle
Old 03-09-2013 | 10:51 AM
  #4536
c130aviator's Avatar
you should shim it if its open at idle, being open sometimes causes idle to stumble and make the car run like crap. I threw one in mine and can hear it slightly higher around 1500rpm coming off off throttle.
Old 03-09-2013 | 11:42 AM
  #4537
BLAZIN07SS's Avatar
I'm too JDM for you
bov open at idle shouldn't effect idle quality. It's all before the maf. that being said, I have the unpainted spring in my tial q and it doesn't stay open. the unpainted spring is for -16 to -19inhg and I pull -21inhg at idle
Old 03-09-2013 | 01:17 PM
  #4538
thats a good point about it being before maf, the reason i said that it would effect idle is because the directions with my turboxs bov said it would cause stumbling. I added the shim because i was getting noise in my chassis since it was bolted to the pipe. and the pipe is bolted just under my windshield water bottle. It kept the bov from bleeding off air at a higher rpm and would keep idle less noisy from the chassis vibration. Its hard to describe but there is a video of it around here somewhere, sounds like a bear growling in the floor.
Old 03-09-2013 | 06:45 PM
  #4539
So I took the piping off today and pressurized it to 25 psi. Nothing...
So far I have done the following:
Tested WG actuator to 20 psi, actuates.
Tested WG actuator without bc, and vented to atmosphere. still only 9 psi
Pulled piping, clamped end to turbo closed with a bottle, clamped tb closed with a 3" can. Pressurized to 25 psi. Nothing leaks.
Checked turbo, no axial play whatsoever (very good thing), however there is lateral (up and down play) but I dont feel or hear the turbo under boost.
I made a video that is 3 minutes long of every part of my manifold, turbo, downpipe. and watched it over and over, no soot, no cracks no loose anything.
Since the performance of the turbo has decreased over a 4 week period from 22 psi to 9 psi, I am assuming dirty oil or new motor build crud has messed with my bearings in the turbo. So I am now considering a rebuild with Forced performance and upgrade to their FP Green turbo internals. FP green makes awesome turbos for STI's and EV0's. Their internals would take me to 59LB a minute. So thankful for so much 20g support out there due to DSM's and JDM's.
Old 03-09-2013 | 07:02 PM
  #4540
nwss's Avatar
Well at least the turbo went not the motor lol
Old 03-09-2013 | 07:16 PM
  #4541
well, i just went for a drive and thought to myself the only thing I didnt check was the IWG flapper. If it got crap in it, melted, failed, something... it would let exhaust gas by without fully closing to allow the turbo to full spool, and would explain only allowing the car to boost to 9psi. Need to pull my down pipe (vband, 1 bolt ) and look in there to see if its opening when I actuate the WG. WIth a 15lb spring it should stay shut until the boost on the turbo overcomes the spring, forcing the flapper open and allowing gas to bypass the turbine.
If it were the actuator spring it would allow the turbo to spool unctrolled with it vented to atmosphere so its not that. I already did that test.
Old 03-09-2013 | 10:25 PM
  #4542
klutch814's Avatar
boost leak tested tonight with a compressor without a regulator.. at first it held nothing.. found it leaking out my maf sensor i have the lsj cold side. took off cleaned and re tightned it held 10 psi .. but still leaks there. anyone have this problem?
Old 03-09-2013 | 10:28 PM
  #4543
MP Cobalt's Avatar
my car pulls like -26inhg at idle hahah vacuum monster lmao
Old 03-10-2013 | 10:55 AM
  #4544
zrated89's Avatar
mines -22-23hg now where on the blower it was 18-20
Old 03-10-2013 | 05:53 PM
  #4545
mine is at -20 vaccum as well. I just dont get why my car isnt boosting over 10 psi any longer. I have checked every possible thing. I thought it was shaft play than hahn told me it wasnt, called me back and told me to troubleshoot but I already did everything he asked. Car runs great just cant figure why it has slowly decreased in boost since the first day I dyno'd it. Wondering if it is in fact my wastegate actuator.
Old 03-10-2013 | 11:30 PM
  #4546
zrated89's Avatar
Well tried tuning today didn't go so well car pulls like a raped ape on only 18psi. We were maxing out the maf though. Was seeing 67lbs per min. Gonna try a few more things anyone else have this issue with 3 inch piping ?
Old 03-10-2013 | 11:31 PM
  #4547
zrated89's Avatar
External wastegate ftw
Old 03-10-2013 | 11:40 PM
  #4548
Bad-A-SS's Avatar
Gah so what do you feel like your making right now with only 18 pounds
Old 03-10-2013 | 11:43 PM
  #4549
i have read several people going to 3.5" piping on the maf section of pipe.
Old 03-11-2013 | 12:55 AM
  #4550
jonnymerk's Avatar
I have posted about this several times and recently. LoL everyone spams new posts in here lately not so much reading. You can try to go to 3.5 in pipe section for the MAF. This often helps and is inexpensive.
Quick Reply: Official Turbo LSJ thread!!!
